'87 Targa
Passenger window switch location
Totally trivial, similar to the armrest topic... I purchased new OE style AppBiz door panels. I purchased the replacement switch clips and had AppBiz install them. However, they opened the rear punch-out, whereas my originals located the switch in the front one.
Bob at AppBiz said it's 50/50 which location the passenger side switch is in. I've searched out several dozen photos, and can't find any that show switch in the rear spot. Can anyone confirm if the rear spot for the single passenger switch was ever used? ![]()
On my '87 coupe it's the front spot.
Both my 86's the passenger switch is the front cutout. - just went out and double checked for you.
Hope that's not bad news...
1986 911 Coupe 1986 911 Targa |
PCA Member since 1988
I believe that the board is the same on the left and right, it just depends which side they upholster, so there are two cutouts to allow it to be used in either orientation. The drivers side has two cutouts in the metal inner door for two switches. Check that the passenger side has two cutouts, otherwise, the your switch will not fit into the inner door.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
'87 Targa
Thanks 5495bb and fallingat120mph for checking. And thanks PeteKz for the feedback.
Agreed, I expect the dual punch-outs in the card and door frame are for universal support of LHD and RHD markets. I think moving my pass switch to the rear location is doable. The wires seem a little short, but might have some play. I am trying to NOT be a nit-picky arse about. If I can find a single example of an original car with the switch in the rear spot, I'd probably live with it. I mean, it seems like a waste and hassle to get them replaced, for both me and AppBiz. But, it doesn't seem right. Does it? Any opinions?
Man, I hate when I order/fix/replace things and they are not what they should be or what I expect them to be as new/repaired, etc.
I never regret sending things back and having it done the way I am comfortable with. I've got a couple 911's and two older Land Rovers that have had quite a bit of interior work done. I've gotten the comment "well no one will see it" or worse "you'll be the only one who knows". The only time I didn't take a car back and correct is the one thing I still notice to this day - headliner in a old LR Discovery - and this is 2 years later. Be civil and polite and have it corrected if your gut tells you to... As they say, my 2 cents. Erik
Its the front cut out on my 87
Never seen it positioned anywhere but the front, but its no biggie to have it in the rear cutout.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Get it replaced, it will bug you every time you get in the car. Nobody needs that kind of aggravation.
