Go Speedracer, go!
SpeedracerIndy's Avatar
Can this be removed?
Is there a way to remove the bucket behind the headlights? This is on a 81 Euro SC. I have a small dent behind the headlight which is also right behind the oil cooler. I would rather remove the headlight bucket than the oil cooler. I noticed a 13mm bolt on the bottom of the headlight bucket and it looks like the bucket is a separate piece. Any suggestions?
Old 06-14-2003, 11:26 AM
Paul Thomas's Avatar
The bucket is welded in, that nut is probably a ground. Rmoving the cooler is your best bet. Have you tried paintless dent removal? These guys can do some wild stuff.
Paul
My ignition is retarded.
Old 06-14-2003, 01:38 PM
Go Speedracer, go!
Paintless dent removers is my next move. I removed the oil cooler and the headlight bucket is still in the way. I figured it was welded in. I think the bolt was for the horn.
1981 SC ROW Coupe
Old 06-14-2003, 02:56 PM
