jakermc's Avatar
DME - Where does this wire go?
'84 Carerra engine won't start so I peaked under the front seat to see if exchanging the DME relay would do the trick. What I discovered is a loose wire that is attached to the female connector for the DME relay. It wraps around the back and was sitting on the left side (when looking towards the rear of the car). What does this do and where does it go? A picture of a properly hooked up wire would be appreciated.
Thanks.
Old 06-14-2003, 07:00 PM
Irrationally exuberant
ChrisBennet's Avatar
One of those is used to set a jumper/mode I think i.e. it doesn't go anywhere on some cars. Another connector like that may go to the barometric pressure unit (looks like a bell). (This is from a very poor memory.)
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-14-2003, 08:01 PM
Lorenfb's Avatar
You're right on Chris. He doesn't need to be concerned about it.
It's only a jumper for some markets, e.g. Japan.
Good luck
Loren
Systemsc.com
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 06-14-2003, 08:33 PM
