Throttle bellcrank - URO part not showing G50 fit but same p/n. Different?
I'm trying to replace a bent factory black bellcrank that looks like it's seen some bends/tool/rock impact prior to re-intalling motor/transmission.
I have the p/n as: 911-423-017-01-OEM with the genuine part shown here: https://www.pelicanparts.com/More_Info/91142301701.htm?pn=911-423-017-01-OEM&bc=c&SVSVSI=0590
and the URO P/N looking like the same BUT listing only up to 1986 (so 915 not G50)
https://www.pelicanparts.com/More_Info/91142301701.htm?pn=911-423-017-01-M253&bc=c&SVSVSI=0590
Does anyone know if these parts are actually different between 915 transmissions and G50 for the throttle bell crank?
Thank you!
Old 11-12-2023, 11:23 AM
Carrera 915 and G50 are the same AFAIK. The URO comes with the fitting for the pull rod too.
206 637 4071
Old 11-12-2023, 11:44 AM
Thank you very much!
Old 11-12-2023, 11:58 AM
