Send a message via Skype™ to kyngfish
Another tire question
Running 7s and 8s 16 inch BBS RS on my car.
I need new tires that look good and work well and I had a few questions since it’s been a few years and it seems like there are less options every year. Last time I went for 205/55/16 and 225/50/16. But if I’m understanding tire sizes right then that means my sidewall in the rear is slightly shorter than the front. So marginal that it’s almost equal but still.
I’ve read that some people run 245/45 rear but also that those sizes are better for 9s than 8s.
Just looking at my current setup I had wanted to get a slightly bigger sidewall for the rear. Not a ton of options out there.
I did a Quick Look through old threads but haven’t seen anything all that comprehensive that’s also recent. Feel free to call me out though if I missed anything obvious.
Thanks!
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250
Old 11-30-2023, 11:34 AM
Bill Verburg's Avatar
Thanks!
What do you want a bigger side wall in back?
The stagger is based on weight distribution and power, w/a stock SC/Carrera 205/225 is a good place to b, then you fine tune w/ profile
205/50 instead on 205/55 gives a little more grip at the expense of ride comfort, 205/45 more so
similarly 225/45 gives a little more grip than 225/50 but w/ shorter side wall and less comfy ride.
245/45 has a shorter side wall, so much so the it imparts more under steer to the car w/ a stock 205 front than 225/50 and gives more grip from that as well as the wider footprint. But on an 8 the effect is less pronounced than on a 9
Bill Verburg
Old 11-30-2023, 12:19 PM
I’m not driving on the track. I just like the 16s to have some meat on them. Suspension is street - aggressive so a comfier sidewall is good with me. I’m not pushing this car to the limits. I’m just driving in the hills with my boys in the back seat and my wife in the passengers seat having some safe laughs and making memories.
Being totally honest I don’t even see options in a set for the existing tires I have.
Old 11-30-2023, 10:55 PM
Uh, I don’t think you are?
205/55 and 225/50 have the same sidewall height: the second number is the sidewall height as a % of the width.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings)
Dynamic CR calculator: https://dcr.questionable.services/
Old 12-01-2023, 05:01 AM
Then the obvious thing to do is stick w/ 205/55 and 225/50
There are plenty of good choices in those sizes.
Bill Verburg
Old 12-01-2023, 05:54 AM
Not going by what I see on tire rack or discount tire direct. But maybe they’re all low on stock after the Black Friday sales.
Old 12-01-2023, 07:14 AM
check what filters are being used, I see 3 pages of choices ~24 separate tire lines
Bill Verburg
Old 12-01-2023, 08:10 AM
