Removing pressed cam box plug
How can I safely remove this cam box plug while the motor is assembled? '79 3.0
'79 911 SC My daily: Love it!!
'73 Targa Gone: Dearly missed
'06 997 C4 Gone: Hated it!
Old 12-04-2023, 08:26 AM
Old 12-04-2023, 08:29 AM
To pull it out the back? Drill it greased up, then thread a bolt in and yank?
1976 914
1986 951
Old 12-04-2023, 12:35 PM
Or just stick a long bar/ socket extensions/ broomstick whatever and tap it out. Use a little heat on it first.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 12-04-2023, 01:07 PM
proporsche's Avatar
i wonder what is the reason you need to remove it?
ivan
1985 911 with original 502 191 miles...808 198 km
Old 12-04-2023, 02:16 PM
PCA Member since 1988
Same question. If you don't have to remove it for a good reason, don't.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-04-2023, 11:05 PM
Yeah I'm trying to imagine the combination of needs that would require pulling that plug while also keeping the engine in the car.
1982 911SC
Old 12-05-2023, 05:54 AM
I just did this a few days ago to add a Clewitt Cam Sync. Luckily, I used a screw driver and pressed on one side and the other side popped out enough to grab it with vise grips. .....came right out.
'81 911 SC
'03 BMW M3 (Sold)
'64 VW Beetle, 2332, 48 IDA (Sold)
Instagram: @j_smallwood
Old 12-05-2023, 05:57 AM
It's a 914 ...
stownsen914's Avatar
Easy with the cam tower on a bench and no camshaft. On an assembled engine (OP's q), I'm not sure how to do it without drilling the plug. Personally I wouldn't be happy to create shavings that would go in the motor. Granted you'd probably be able to get most/all of them out once you removed the plug, but I'd worry I'd miss some and that would be no bueno.
Old 12-05-2023, 01:27 PM
Yup, Clewitt Cam sensor. I drilled and priyed it out. But corrosion on housing made it difficult. Thanks for the input. Now I have to drill and tap into the cam end. Terrifying. Any tips from those who have done it?
Old 12-05-2023, 01:46 PM
proporsche's Avatar
you did not say yet ,why do you want to remove the plug?
Ivan
Old 12-05-2023, 01:49 PM
It was fairly straight forward. I was biting my nails a bit, but after I saw what was behind the plug and how much room there was, I wasn't as nervous. Getting the CAM in position was a harder task, for me. It calls for 120 degree before Z1 on the compression stroke. I had to pull the valve covers off to make sure I knew where that was.
The kit came with a drill fixture. Easy peasy. Collecting the shrapnel afterward was easy with a magnet and vacuum. I took my time and cleaned, cleaned, cleaned. And don't use compressed air. stuff will go everywhere you don't want it to.
'81 911 SC
'03 BMW M3 (Sold)
Old 12-05-2023, 01:52 PM
