Emergency flashers/turn signal problem
My 71 911E was making a ticking sound all the time while driving.
I started by replacing the turn signal relay (#914-618-303-12). It’s shorter in height, but I figured it has been superseded. The flashers still weren’t working properly so I replaced the emergency switch on the lower dash (#911-613-124-31) and it still isn’t working properly.
When emergency flasher button is in, emergency flashers flash very quickly.
When Lt turn signal is activated, emergency flashers stop and the turn signals work properly. Same with the right turn signals.
When emergency flasher button is out, nothing works….no emergency flashers, no turn signals.
It used to be….emergency button in…..turn signals work. Emergency flasher button out, emergency flashers worked.
Not sure what’s going wrong.
Mark
1971 911E targa
Priors:
1955 Speedster, 74 911 coupe, 69 911T coupe, 74 911 slant nose w/928 lights, 03 911 Turbo
Old 12-21-2023, 06:59 PM
Not at all clear what your original problem was. Everything worked except you had clicking?
Then you swapped some parts and created a new problem?
Old 12-22-2023, 01:18 PM
proporsche's Avatar
check your grounds
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 12-22-2023, 01:34 PM
Yes, everything worked, but the flasher was making an annoying clicking sound all the time so I put a new flasher in a that’s when nothing worked correctly
Mark
1971 911E targa
Priors:
Old 12-22-2023, 02:16 PM
Originally Posted by proporsche View Post
check your grounds
Ivan
Yes, I did check all the grounds in the trunk and under the dash
Mark
1971 911E targa
Priors:
Old 12-22-2023, 02:18 PM
proporsche's Avatar
grounds to the light units would be better...
Ivan
Old 12-22-2023, 02:43 PM
The flasher is also used by the brake warning system. Hand brake on or low brake fluid.
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 12-22-2023, 04:29 PM
I would put the old flasher back and figure out what is triggering it
Has it always had this issue?
Old 12-22-2023, 05:24 PM
