Which of these is the speedometer sensor wire?
I’m pulling the engine and transmission on my 1984 Targa.
I’ve disconnected the shift coupler and I think the speedometer connection is one of these wires… but which one and what are the other wires?
Old 12-30-2023, 10:20 AM
The 2 brown/red wires are for the speedo sensor. I'd need to look at a wiring diagram when I get home for the other 2. It looks like they are brown/yellow?
Sent from my SM-G991U using Tapatalk
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 12-30-2023, 10:30 AM
I know that JW recommended you to pull those wires... but I have always removed the sensors attached to the side of the gearbox and hang it out of the way. There is no need to mess with the wires in the tunnel. Just me.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-30-2023, 01:06 PM
Originally Posted by jbell959 View Post
The 2 brown/red wires are for the speedo sensor…
Is that the wires on the left or right side of the photo above?
Old 12-31-2023, 09:49 AM
Right
Old 12-31-2023, 10:25 AM
The connector under the tie wrap is speedo. Disconnect the wires and remove with the engine and trans. If u leave the wires behind u have to cut hard to reach and hard to replace factory reusable wire ties. U have to open the rear cover to undo the shift coupler so disconnect the wire connector there. As a line and unit mechanic for 50 yrs I hate short cut approaches to these jobs.
Old 01-01-2024, 08:39 AM
Thanks everyone! These responses were very helpful!!
Old 01-01-2024, 05:08 PM
