Which of these is the speedometer sensor wire?
I’m pulling the engine and transmission on my 1984 Targa.
I’ve disconnected the shift coupler and I think the speedometer connection is one of these wires… but which one and what are the other wires? ![]() |
The 2 brown/red wires are for the speedo sensor. I'd need to look at a wiring diagram when I get home for the other 2. It looks like they are brown/yellow?
Sent from my SM-G991U using Tapatalk
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
I know that JW recommended you to pull those wires... but I have always removed the sensors attached to the side of the gearbox and hang it out of the way. There is no need to mess with the wires in the tunnel. Just me.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
The connector under the tie wrap is speedo. Disconnect the wires and remove with the engine and trans. If u leave the wires behind u have to cut hard to reach and hard to replace factory reusable wire ties. U have to open the rear cover to undo the shift coupler so disconnect the wire connector there. As a line and unit mechanic for 50 yrs I hate short cut approaches to these jobs.
Thanks everyone! These responses were very helpful!!
Thread Tools | |
Rate This Thread | |
