Removing Lug Nut Locks
Hi All,
I’m having a horrible time removing one of the wheel locks on my 911, to the point where it’s actually broken as you can see in the picture. I’ve used a breaker bar and impact wrench so far. Any other ideas for how to remove this?
Old 02-18-2024, 03:02 PM
Following
Old 02-18-2024, 03:44 PM
Air hammer pointed bit. Dig in and rotate in the off direction. Don't let it slip and hit the wheel. Wear gloves and face shield and hold the bit near the end for control.
206 637 4071
Old 02-18-2024, 03:53 PM
Check this thread out for some suggestions: Locking lug nut
I've also found that the factory recommended a hole saw for removing a sheared nut.
Old 02-18-2024, 04:01 PM
pound on the nearest size impact socket and use your impact gun
Old 02-18-2024, 04:04 PM
proporsche's Avatar
i always use the no2 pipe drill..works great..just you have to be careful when you get closer to the rim..I have debt mark on my pipe drill so i know when to stop...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-18-2024, 04:20 PM
Take a mini sledge and beat a socket onto that and scare it off with an impact gun.
Old 02-18-2024, 04:42 PM
tobluforu's Avatar
I have done it with a 12-point socket, pound it on like stated. But first you need to apply Kroil or something and let it sit for some hours. Every little bit helps.
Old 02-19-2024, 04:14 AM
I got a cheap broken lug nut removal tool set off of amazon. it worked very well. Basically a big broken stud extractor socket
Old 02-19-2024, 07:19 AM
Old 02-19-2024, 08:58 PM
nene's Avatar
This happened to my 86. I used the tools above but the nut was too close to the wheel so
I ended up using a hollow bit to take it all the way down, but be careful not to damage the
wheel.
Serge
Old 02-23-2024, 12:35 PM
