Irrationally exuberant
ChrisBennet's Avatar
Transmission shaft input leaks, help!!
Hi everyone,
My '86 915 transmission is leaking from the input shaft seal.
Background:
- no leaks for years
- body checked a guard rail at Lime Rock last year
- get car back from body shop drive about a week and a couple of track days, input shaft starts leaking
- rebuild transmission and replace input shaft seal
- two weeks later, input shaft starts leaking again
When I had the transmission apart I didn't notice any scoring on the input shaft. I did not check the input shaft for straightness.
TIA,
Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-21-2003, 06:13 AM
Senior Member
Doug Zielke's Avatar
Just a question, Chris.....
How was the bore the seal sits in?
The seal on my 915 had obviously been replaced at one time, and a PO/M damaged the edge of the machined surface a bit. I used a machinists de-burring tool to clean it up. I also put a little 3-Bond 1104 on the outer edge before I drove it in. No leaks.....yet.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 06-21-2003, 08:00 AM
That's a good question. I don't know. It wouldn't kill me to replace the guide tube I guess.
-Chris
Old 06-21-2003, 09:44 AM
