magilla's Avatar
Question Fender rolling has started. How far around?
I recently went to my first DE. It rained most of the weekend, but we did have one dry afternoon session. As my speeds picked up in the (relative) dry, I heard a pretty scary scraping from the front on corners. My instructor checked it out, and we cncluded that the tires were rubbing on the fender lip, as they were all scraped up.
So, I have started to roll the lips in the front, so I can go and drive faster without the ugly noises. My question is this: How far does the lip need to be rolled? 45 degrees? 90 degrees? Also, what arc needs to be rolled?
Maybe someone could post a pick of their wheel well and show me where they started and where they stopped. I am guessing that the seam where the bellows meets the fender is a good spot to start on the front, but what about the back? How far do I need to go?
Thanks!
Old 06-21-2003, 08:49 AM
Formerly bb80sc
Vipergrün's Avatar
Magilla, mine are rolled at about 45 degrees from the 10-2 O'clock position on the fender.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 06-21-2003, 10:14 AM
magilla's Avatar
Thanks, Brad. That was the kind of info I was looking for. What size sneakers are you wearing? 225/ 16? 225/ 17?
'83 SC Coupe- Blk/Blk
'03 Daughter- 10fingers/10toes
Old 06-21-2003, 10:21 AM
Formerly bb80sc
Vipergrün's Avatar
225/50 16's
Cheers
-Brad
2015 Cayman GTS
Old 06-21-2003, 11:12 AM
Harlan Chinn's Avatar
Louisville Slugger or similar baseball bat works very nicely. Roll about 12 to 15 inches each side from the center of the wheel arch. Starting from the center of the wheel arch and rolling outward to provide a nice transition. 45 degrees minimum, steeper the angle the better but you risk cracking the paint.
Harlan Chinn
Pacific Northwest Region
1998 Carrera S ArcticSilverMetallic
1982 911SC PazificBlauMetallic
Old 06-21-2003, 11:32 AM
