Chain fence eating turbo
Stronger G50 CV and axles? Broke mine
Anyone know where to get stronger axles for a G50 on an ‘87 911 that won’t require a small loan?
Busted my passenger side last night “testing” new rear tires during a 2nd gear shift.
Old 03-12-2024, 07:00 AM
Wow, didn't know this was a weak point on G50s.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 03-12-2024, 07:38 AM
gearhead
It’s not until you’re around triple stock HP.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 03-12-2024, 07:45 AM
3rd_gear_Ted's Avatar
My 3.6L track car with a 915 has Ford axles spec'd for a Cosworth Escort.
Not sure on G50 fit.
Everything on them is just a little bigger, thicker and a bit heavier.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 03-12-2024, 07:51 AM
By my calculations, I should be 625.
Referencing another 3.2 dyno’d 260hp with 993 SS cams.
260 x 2.4 (1 bar atmos + 1.4 bar of boost) = 624 HP
Don’t have a dyno sheet to prove yet.
Old 03-12-2024, 08:26 AM
Tippy, where did they break? Got any pics?
Old 03-12-2024, 09:42 AM
Outer CV pass side
Old 03-12-2024, 11:44 AM
If you have enough HP to break stock, there are a few companies who build beefier axles for offroad racers. A friend who built a twin turbo SC (maintained the stock look & body) was breaking CVs, upgraded them, then broke axles, upgraded those but was then breaking hubs. It was not a 915 tranny, I found him a 993 6 speed and then the other stuff was breaking. I can ask him where he got the axles if you want.
Old 03-12-2024, 12:22 PM
Curious whom that is. If all else fails, I’ll turn down the boost….
Old 03-12-2024, 01:07 PM
I seem to recall Juan regarded G50 axles as a fusible link.
Because they were a lot cheaper and more convenient to replace than breaking things inside the transmission.
He posted pictures of some twisted into interesting pretzel shapes. Pretty sure that was when he was still actively racing - which would put it before his last build with the 30PSI map that made more than 700HP at the wheels.
'77 S with '78 930 power and a few other things.
Old 03-13-2024, 08:18 AM
Heh. Tried to find the picture Juan posted that I thought I remembered - but found his reply to your question in 2012 first. Bonus footage of broken G50 axles at the drag strip:
Originally Posted by juan ruiz View Post
Originally Posted by Tippy View Post
Question is, will the G50/01 withstand this much power off the line in first?
Yes, Axle's won't either the inner hub our outter hub or both
(Quoting & links gussied up) from https://forums.pelicanparts.com/porsche-911-technical-forum/703732-x-post-g50-01-1st-gear-launching-longevity-boost.html#post6967159
Old 03-13-2024, 09:39 AM
Yes sir, I’m going to just replace axles so it doesn’t take out the trans
Old 03-13-2024, 03:29 PM
