PCA Member since 1988
SC distributor spring orientation
I confess that I was a taking apart my dizzy to clean and lube it (Guenther's directions), and I pulled on the star wheel enough that the springs came off the posts in the lower part of the distributor cup. So I lost the orientation (one thicker spring and one thinner). Does anyone know which spring goes to which post?
Thanks in advance.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-04-2024, 09:12 PM
AndrewCologne's Avatar
I answered here:
https://forums.pelicanparts.com/911-engine-rebuilding-forum/1159911-sc-distributor-spring-orientation.html
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control
All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models:
https://nineelevenheaven.wordpress.com/english/
Old 04-04-2024, 10:08 PM
Andrew, got it, and thanks again. PK
Old 04-05-2024, 11:26 AM
