911SC - advance timing stuck in dizzy - how to fix?
Hi,
I got a 911 SC from 1978, which has got the advance timing stuck in the ignition distributor. I feel it doesn’t move when I try to push ring in the distributor. Also tried to put a vacuum pump with hose on it, the vacuum can on the side holds vacuum and it feels like it tries to push the advance timing but can't.
Does anyone have instruction on how to fix this problem? I guess I need to disassemble some stuff on the dizzy, so some helping instructions would be helpful.
Thx
Old 04-09-2024, 03:53 AM
Schulisco's Avatar
https://nineelevenheaven.wordpress.com/maintenance-of-the-distributor/
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 04-09-2024, 04:55 AM
Many many thx Schulisco - just what I needed. :-)
Old 04-09-2024, 06:45 AM
Schulisco's Avatar
Welcome :-)
I also recommend the YT Channel from KlassikATS, they also got videos concerning the distributor on various 911, but unfortunately not for the SC's yet. Hope they will come soon. The Marelli is different to the Bosch ones, but you get an impression how to proceed.
https://www.youtube.com/@klassikats/search?query=bosch%20distributor
Be aware about the ignition timing when putting it back into the car. I recommend a digital timing light gun like the Equus 5568 Motortester, with that you can test the advance quite easily.
Thomas
Old 04-09-2024, 09:11 AM
