87 coupe - front end tracking issue
Thoughts on where & what to look at please.
‘87 3.2 Carrera coupe; Euro ride height. I bought the car 9 months ago fully sorted. Driven it 5k miles in 9 months - 89k miles now.
When I punch the throttle, the front seems to lower a bit and jump slightly to the left and when I depress the clutch to shift gears in a more aggressive drive, the front seems to lower a bit and jump slightly to the right. So, opposite movements when accelerating or decelerating. There is also a mild drift in the steering that wasn’t there before this started.
I’ve looked under the car and don’t see anything that appears to be broken or out of place as far as I can see; but have not been able to get it on a lift yet.
What should I be looking for and where?
Thanks much!
Old 04-10-2024, 07:26 AM
Struts, ball joints, sticking brake caliper, sway bar.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 04-10-2024, 01:21 PM
Alan L's Avatar
My guess would be worn/soft 40 yo rubber suspension bushes. And maybe not just the front ones.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 04-10-2024, 01:38 PM
All of the above, I just went through it. My main problem was sway bar bushings but the whole front was redone. Rear later, $ you know, and I wanted to see how the front was sorted first anyway. That said centrifugal force can add to your problem. AKA load and unloading.
Old 04-10-2024, 05:03 PM
Thanks much for the help! I’ll update when I know more. Much appreciated.
-Carl
Old 04-11-2024, 06:37 AM
Update: just got the car back from the shop that sorted it a year ago. Replaced sway bar bushing and a sway bar bracket. All good. Thanks much for the help all!
Old 06-05-2024, 07:55 PM
