Talking Hi-Torque Starter Installation Notes/Questions
I'm installing the hi-torque starter acquired from our host on my '83SC with a 915.
The barrel nut doesn't properly engage at the base of the starter, and a washer doesn't fit either. The lip around the mounting hole is too close to the stud. Looks like I will have to mill out a bit of the base - anyone else encounter this? Is taking a Dremel to the starter base the preferred option here?
Also wondering if others have clocked the starter base so that there's more clearance for the heat exchanger tube - it's super tight.
Please share your experience - thanks, Pelicans!
Old 04-16-2024, 07:16 AM
I clocked 85 so terminals are almost straight up, battery cable just fits. I had to get a new heater hose The old one may have been trimmed at some point and didnt reach by 1/2”.
Old 04-16-2024, 07:29 AM
I didnt need to make space for the washer.
I did have to clean some more!
Old 04-16-2024, 07:39 AM
Yep make it flush , mill or what ever u have
Also check the depth of the nose gear as compared to the old starter, they need to be exact
too many depths are incorrect in my experience , new ones are too deep
Ian
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 04-16-2024, 08:16 AM
On mine I was able to use washers since it does not have the "cut down" you have. Not sure what the purpose of cutting that down was by the manufacturer. I also had to add a short battery cable extension since no matter how it was rotated, the original cable was just a bit too short. I don't recall any issues with the heater hose, however I did replace mine since they were pretty ratty.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 04-17-2024, 06:28 AM
Well, Pelican sold it, and marked it as “Yes, it fits,” so not sure why the depth would be an issue. How would one check for proper depth of the nose gear?
Ian
Old 04-17-2024, 07:08 AM
