evan9eleven's Avatar
Need help with a measurement please
Hi everyone,
Would a few of you with longhood cars be so kind as to measure from the leading edge of the hood to the lower pointy end of the Porsche badge for me?
I think the factory didn't have a standard, as I've seen anything from 161mm to 183mm. I'd like a few more data points before I drill my new hood. Measurements in inches will also be gladly accepted
Thanks in advance!
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 04-22-2024, 11:11 AM
Schulisco's Avatar
https://forums.pelicanparts.com/porsche-911-technical-forum/900680-longhood-emblem-location.html
https://www-pff-de.translate.goog/thread/2687668-position-porsche-emblem/?postID=152805591&_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp#post152805591
Thomas
1981 911 SC Coupé, platinum met. (former tin (zinc) metallic), Bilstein shocks, 915/61,930/16,WebCam20/21, Dansk 92.502SD,123ignition distributor with Permatune box as amplifier,Seine Systems Gate Shift Kit,Momo Prototipo. Want to get in touch with former owners of the car. Last registration in US was in 2013 in Lincolnshire/lL.
Old 04-22-2024, 01:05 PM
Thanks Thomas, I've been searching but hadn't seen those two threads. Much appreciated!
2004 Boxster S
Old 04-22-2024, 01:46 PM
MBAtarga's Avatar
22cm from the edge of the hood to the hole locations for future reference.
Mark
'83 SC Targa - since 5/5/2001
Old 04-22-2024, 05:23 PM
Thanks everyone. The thing that motivated me to ask for measurements, is that there doesn't seem to be a standard, as I mentioned above. Knowing that the new factory hoods come pre-drilled for a badge at 220mm is certainly a good indication but doesn't explain why so many original cars have completely different badge placements.
For reference the pins on the underside of my new, authentic Porsche badge are 37mm from the bottom pointy end.
2004 Boxster S
Old 04-23-2024, 08:32 AM
Schulisco's Avatar
More information, unfortunately no measurements, but this shows the evolution of the emblem over time:
https://www.turbosition.com/en/porsche-crest
https://www.early911sregistry.org/forums/showthread.php?132020-Porsche-crest-logo-evolution-historians-anoraks-general-enthusiasts-of-the-marque
https://www-pocg-eu.translate.goog/pages/technik/911_964/911_964_Deckelwappen/s_911_Deckelwappen.htm?_x_tr_sch=http&_x_tr_sl=de&_x_tr_tl=en&_x_tr_hl=de&_x_tr_pto=wapp
Old 04-23-2024, 09:38 AM
After much consternation I decided that I'd just go with what appears to be the Porsche standard for new hoods, 220mm from leading edge to holes.
Two reasons:
1) if I'd been smart and purchased a factory hood from Porsche, this is where the holes would have been anyway. (Note to self and others, don't buy Dansk body panels!)
2) There is a support brace welded in around the hood perimeter, and the holes need to be at least 205-210mm from the hood leading edge if the speed nuts are to clear this brace on the underside. If the factory sees fit to pre-drill at 220mm, then that has to be good enough for me.
Borrowing from Mike's post here:
Originally Posted by SpyderMike View Post
I'm happy with the placement in the end... just need to finish the car now!
Here is the underside with the holes at 220mm:
2004 Boxster S
Old 04-24-2024, 02:58 AM
