power window relay switch
Read that changing out the power window relay switch could speed up my power windows. But where is the relay switch located and how difficult is it to get to ??
Joe G
Old 05-05-2024, 07:53 PM
Not sure what car you have. It would help if you could add it to your profile. I see in another post you mentioned an 88 Cab. If this is what you have, power window relay is located behind dash instruments and is the first one at the far left.
If car is older, like a 3.2 from 86, power window relay is one of the round relays in fuse box. It should be the second one starting from windshield. Check on the plastic cover to confirm.
Not sure to understand why changing this relay would help speed up windows. As a relay switch, it is either on (switch closed) or off (switch open).
Gilles
RoW 88 Carrera coupé
Old 05-06-2024, 06:15 AM
Thanks for the reply.and i will update my profile.
Old 05-06-2024, 12:09 PM
Look inside your doors see if there’s a little piece of metal in there, either your windows are gunked up and or your return spring pivot is busted.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 05-06-2024, 12:26 PM
