Matthew_VA's Avatar
Speedometer Help
been reviewing several thread but am a bit stumped.
('84 Carrera) A couple times over the past few months I would notice my speedometer needle fluctuating when I was at speed. Then, the other week it died, stuck on zero (and odometer and trip meter don't move). I assumed it was the speed sensor so just replaced it, with a URO part (91160620900), went out for a drive but nothing...
I checked the speedo, where I connected both sensor signal terminals and the needle would move, I then did the same thing at the connection under the access panel behind the seats and got the needle to move again.
Could the part be faulty or is it not installed right--I did take it out and reinstalled... Just confused.
TBD
Prior: '84 911 3.2 Carrera, '83 911SC Targa
IG: @heuersandcarreras
"I want to use it. That's what 911s are for." - Richard Hammond
Old 05-29-2024, 10:59 AM
I've had a couple of people tell me in the past few months that they received DOA speedometer sensors. You can easily test them by passing a magnet across it. If you take it out and connect it to a meter you will see it go from open to close or, if you have it in the car with the power on you will see the needle move.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 05-29-2024, 11:36 AM
Matthew_VA's Avatar
OK, will give that a shot. thanks!
TBD
Old 05-29-2024, 12:11 PM
