Yet another A/C pressure question.
I did a search with little info other than I should I replace my Nippendenso compressor.
With engine running at ~2000+ rpms I borrowed a friend of a friends pressure gauge and I found my low side pressure immediately runs ~25 then it creeps back up to ~45 psi. Is this a bad seal(s) in the compressor or is it not enough R12?
With the engine lid closed, and running ~2000 RPMS the sight glass appears to be half liquid and half air. The ball is on the bottom.
As far as I can tell, everything appears to be original. R12 to the hoses to the compressor.
Thanks in advance.
Nick
'85 Carrera
Old 06-24-2003, 10:22 AM
scottb's Avatar
If your car is all original, and you haven't charged the system recently, chances are that you're low on freon. The original hoses were designed to leak, and the system requires topping-off periodically. If you're environmentally conscious, the thing to do is replace all of your old hoses with new barrier hoses, which will not leak R12 into the atmosphere. Then recharge your system.
1984 Targa
Old 06-24-2003, 10:30 AM
OK so the head pressure drops with constant RPM is still an indication of low freon/charge?
And not a bad compressor/seal?
That's what I was hoping for. I don't want to add more Freon just to find out that my compressor is bad and have to evacuate and add new Freon.
Nick
'85 Carrera
Old 06-24-2003, 10:41 AM
scottb's Avatar
Look at the underside of your rear deck lid, over near the compressor. If you see oil and grime on the deck lid, then the front seal of the compressor is shot.
1984 Targa
Old 06-24-2003, 10:52 AM
Thanks for the replies.
I don't see any there. However, it hasn't been running in a while.
Are there rebuild kits? Or is this a matter of taking it to someone, or buying a rebuild?
Nick
'85 Carrera
Old 06-24-2003, 01:07 PM
scottb's Avatar
I've heard you can get rebuild kits here. If you want to buy a rebuilt, you might try the same company, or try Compressors International in Van Nuys, California. I bought mine there, and the prices were VERY good.
1984 Targa
Old 06-24-2003, 01:52 PM
The sight glass should be clear and look like there's nothing in it. If you see bubbles (what a sentence! ) you are low on refrigerant. The pressure rising and falling could be the expansion valve opening and closing. You normally would not have that big a swing of pressure but when you're low on refrigerant it might happen. Bad seals in the compressor will not raise or lower your pressure but "could" be the source of a leak.
Old 06-24-2003, 03:32 PM
OK, I will try six more ounces and see where the glass is at.
Thanks.
Nick
'85 Carrera
Old 06-24-2003, 04:45 PM
OK, added another 6 oz. The sight glass is 3/4 full with liquid, yet my cold air output has fallen. My average cold air output is ~60 degrees.
MY low pressure side is ~25 - 30psi at 2000 rpms. And it no longer changes. Do I need another 6 oz?
Is seems to have been working better with less refrigerant.
The high pressure side, seems hotter, though I haven't measured it yet.
Suggestions?
Thanks.
Nick
'85 Carrera
Old 06-25-2003, 05:43 PM
scottb's Avatar
I was talking to Ron Maxwell at ProCooler yesterday, and he said that it's better to err on the side of a bit less refrigerant rather than too much. Given the cost of R12, I'd put in another ounce or two. If the output keeps going up, then you'll have to remove some.
1984 Targa
Old 06-25-2003, 05:48 PM
Should it "leak" out the high pressure side then?
I keep wondering though, because the glass is "empty" when it idles.
Also, When I first turn the A/C on it gets cold for the first five minutes or so, then it all slowly warms back up.
Nick
'85 Carrera
Old 06-25-2003, 05:53 PM
Sounds like you have too much water in your system. I would predict your system needs to have the R-12 removed, a new receiver/drier installed, the system evacuated and R-12 reinstalled or convert the system over to R-134a. Cheers, Jim
Old 06-25-2003, 07:29 PM
NNNOOOOOOOOOOOOOooooooooooooo
Could be anything else???
I suppose that's better than needing a new compressor.
Nick
'85 Carrera
Old 06-25-2003, 07:55 PM
Have you considered asking these questions over at the forum at www.ackits.com. They seem to know their stuff
Old 06-25-2003, 08:44 PM
I didn't want to register...
I will do that now.
Thanks.
Nick
'85 Carrera
Old 06-25-2003, 09:17 PM
I'd suggest following Jim's advice. You want to add the correct amount of refrigerant. Too much is no good. Just right is the correct amount. Take it to a pro shop and have them evacuate and check the system before filling the system.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 06-26-2003, 12:57 AM
What is the high pressure?
That will help determine whether you are getting close to the correct charge.
With a correctly charged and operating system and engine at 2K, fan on high, thermostat set at coolest setting, engine lid as close to closed as possible you should have a low pressure of 25-30 with a slight movement of pressure as the expansion valve opens and closes. The sight glass should be clear with no bubbles.
It is unlikely that moisture has gotten into the system unless the system has lost its complete charge or has been recharged with contaminated refrigerant.
Don't think your system has a bad expansion valve as it now seems to stablize around 25#.
If your deck lid is open you will have extremely high head pressure and some of the problems you have described such as bubbles in the sight glass. Even with correct charge with the deck open you could see bubbles.
Old 06-26-2003, 06:00 AM
jdowty3's Avatar
Don is right. With the deck lid open, the head high pressure goes up and can screw up the readings. Set a box fan on top of the deck lid to cool the rear condenser while your working with the compresser.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 06-26-2003, 06:46 AM
scottb's Avatar
Don, Jim: With the decklid closed, engine at 2,000 rpm, switch on high, what should the high pressure reading be (with low of 25-30)?
Thanks.
1984 Targa
Old 06-26-2003, 07:05 AM
Depends upon the ambient temperature and the type of Freon; pressures go up as the outside air temperature increases. R-134a pressures are higher than R-12 for a given air temperature. Ambient air temperature is measured two inches or so in front of the intake of the condenser. Jim
Old 06-26-2003, 07:52 AM
