Pelican Parts Vendor
Help- 911T 2.7 Runs, then dies instantly CDI Good
Hello
Seeking the infinite knowledge out there, to solve this running problem. Recently, my 2.7 Carb'd 911T is dying. I start the car cold, and during warm up it instantly dies. Then just cranks with no spark. It's clearly an electrical problem. Thinking it was the CDI box, I sent it off to the great Bob Ashlock. He confirmed the box is working as it should. Checked the powerlead to CDI and voltage is hovering around 6.7, when it should be 12V. Batteries are reading around 11.6 at the time of the incident. This has happened once before, and the car fired back up and ran great for an evening blast. Appreciate any ideas. This weekend is my birthday and I sure would love to drive the car. Thank you Jeff
Jeff Brown Vice President Product Development Griot's Garage |
Jeff,
A good battery should be reading in the mid 12s without the car on. I would charge or replace the battery as a first step. Could be that after all the draw from the starter, there just isn’t enough to run the CDI. Rutager
Rutager West 1977 911S Targa Chocolate Brown |
I installed a modern internally regulated alternator and am concerned it's not being properly triggered due to the inadequate resistance in the gauge light bulb. I've got to wire up the resistor. Am concerned that the system isn't charging as it should.
PCA Member since 1988
Jeff, you may already know this: The Gen light must be an incandescent bulb, NOT an LED. It initiates the alternator field by sending current back through the bulb to the alternator. Too little resistance would not be a problem, but rather too much would be a problem.
That's easy to check: When you turn the key to ON, does the Gen light illuminate? Then when you get it started, does the Gen light go out? If so, the light works and is feeding current back to the alternator. Then check the running voltage. That should be around 14V. If the voltage to the CDI is around 6.7, instead of 12.6, then you probably have a poor connection in the wiring harness. Pull apart the connectors and clean the pins and spring the pins so that they make better contact.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Typically, a 100 ohm resistor is added in parallel with the alt bulb.
Dave |
bulletin
Not sure this addresses your problem, but there is a tach bulletin for the regulator/resistor requirement.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Jeff,
Sounds like you have the batteries under control. Have you checked grounds? Like from transmission to body? You might need to start where you’re getting the low voltage and work your way back until you find proper voltage to find the issue. Rutager
[QUOTE=al lkosmal;12268134]Not sure this addresses your problem, but there is a tach bulletin for the regulator/resistor requirement.
Thank you for your reply, Al. I have seen that bulletin, as Allen provided it to me during my alternator replacement. I have ordered the resistors and electrical connectors. It seems it would be worthwhile installing that to rule out the charging issue. My laundry list of to dos continues to grow. But that is why we love these old cars...right? Will keep you posted as I work to resolve this.
At this point, your voltmeter at the battery should indicate an increase in voltage, e.g. 1-2 volts. By the way, the Bosch 3-pin CDI unit rarely if ever fails, not like the 6-pin ones. Why waste your money? The 3-pin CDIs typically fail when the battery is jumped in correctly, or a tech shorts the ignition coil to ground while troubleshooting.
Dave Last edited by mysocal911; 06-20-2024 at 10:14 AM.. |
I advocated for him to have it rebuilt since the unit is 50 years old and with the batteries dying frequently it could have been damaged by jumping it off.
The car does see some distance trips and its worth the piece of mind.
1976 911 1976 914 1986 951 |
1. mechanically system incur increased failures with time 2. electronic systems incur more failures in the early time phase and decrease with time
Dave |
You cant seriously be arguing that it is a waste to update a 50 year old component.
That would just be stupid.
Jeff, following up this thread, I've been away for a few days:
If the charge indicator light goes out when the engine is running, then you do not need the parallel resistor. Now focus your troubleshooting on connections and grounds.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 06-26-2024 at 02:29 PM.. |
1. Same original components: 2. No resoldering of the OEM circuit board for increased reliability: 3. Poor quality installation of so-called "higher quality parts" update: 4. And a paint job with a Torx screw to replace the rivet and just cover the hole (doesn't hold the capacitor like the OEM).
Dave Last edited by mysocal911; 06-26-2024 at 06:12 PM.. |
And yet the car sits as the short Summer moves along. Now, the low voltage I found at the CDI power wire (red on 3 Prong plug) is showing no voltage. Checked Points Dwell at top dead center and there was no gap. I adjusted to spec Next is to check if accessories are working with ignition on...thinking perhaps I have a bad ignition switch. Discouraged...
having had Bob at Ashlock repair a bunch of these i am confident in my recommendation. I also repair vintage cars professionally, do you?
You do carry a spare, right?
Dave |
Jeff, try jumping 12V from another power source in the engine bay directly to the power wire to the CDI. See if it runs correctly like that. Then work your way back to why you are not getting 12V there.
Tags |
2.7 , 911 , dying , electrical |
