Front Shock Issue
My front passenger shock is maxed out towards the fender which is around 2 degrees negative camber. I would like to get it closer to 1 degree. But can not push anymore towards fender to get to 1 degree. Any suggestions? Also my driver side is perfect. Also are the mono balls a rough ride compared to the factory bushing setup. Because at this point not sure how to get to zero or even 1 degree of negative camber. Don’t believe car was ever wrecked.
Old 06-17-2024, 11:05 AM
Do you really want positive camber?
Usually the target is close to zero camber or maybe a bit negative (angled in at the top of the strut)
Old 06-17-2024, 02:00 PM
Sorry I described my issue wrong. Please read again.
Old 06-17-2024, 03:21 PM
Still a bit confusing but if the car is lowered too much it might be too negative to compensate by moving the strut top.
Is there a possibility that a previous owner installed de-cambered ball joints too allow more negative camber?
Yes the mono ball top mounts will add some harshness, but that may be your only solution.
What size wheels/tires are you using, and what is the distance from the ground to the fender lip?
Old 06-17-2024, 05:14 PM
Too much negative is not a problem for the stock setup. Sounds like either a PO installed de-cambered ball joints like Brian says (but that wouldn't explain the driver's side being okay), the car has been damaged, or the strut has been bent.
1982 911SC
Old 06-18-2024, 05:39 AM
PCA Member since 1988
A bent strut is not uncommon. I was able to straighten mine with a hydraulic press.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-19-2024, 12:48 AM
Yep. There's a reason a lot of struts have gussets. On mine the spindles were loose on the struts and the struts were bent--I could never get my front camber right.
1982 911SC
Old 06-19-2024, 06:51 AM
dtwa's Avatar
Might want to check if the car is level side-to-side. That directly affects camber. —Dave
1985 Carrera 3.2 • Prussian Blue Metallic
Old 06-19-2024, 09:39 PM
I will have to check the ball joints. I did have them replaced last year. Also I did just lower the car and it is around 24 3/4”. Both sides are equal in height. I am running 205/55/16 Michelin ps4 all seasons. I am out of town but when I get back I will pull the strut and see how straight it is. If car was damaged they did a great job hiding it. No sign of a respray.
Old 06-20-2024, 09:45 PM
