962 962 is offline
962's Avatar
Installing new tires on my fuchs
Where can i get these valve stems for the fuchs ? Thank-you
Old 06-30-2024, 12:02 PM
Bolt on Chrome metal valve stems (opposed to rubber), seen them at Jeg’s but most tire shops should be able to stock or source them.
Old 06-30-2024, 12:14 PM
962 962 is offline
962's Avatar
OK , Thank-you !
Old 06-30-2024, 12:24 PM
Steve W's Avatar
Or you can just get a set of four Huf RDV021 aluminum valve stems. Same type of valve used on TPMS sensors (minus the sensor) and OEM for Porsche. Much lighter than steel, 1/3 of steel, so less balance weights needed, and the smoother profile and anodized finish keeps cleaner. You can get a set of four under $16 shipped.
https://www.pelicanparts.com/More_Info/36146792829.htm?pn=36-14-6-792-829-M458
Old 07-01-2024, 12:47 PM
Ctopher's Avatar
I’ve been using these on all my cars including my Carrera. They are a tad bit taller than the one you listed. I found this tire supply network site that has other models as well as my favorite model below.
SKU TV-CPV
High Pressure Chrome Valve Stem (130 psi)
Old 07-01-2024, 07:22 PM
Mr. Merk's Avatar
Pretty sure you can get them at most local auto parts stores. We just put some on some BBS wheels
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 07-02-2024, 08:22 AM
I purchased these on the advice of another pelican thread, installed them on my Fuchs over a year ago and they've worked flawlessly since. https://www.ebay.com/itm/383124436278. They look great (to me) against my rims' anodized finish.
Old 07-02-2024, 09:30 AM
Ctopher's Avatar
You would think so, but most shops don’t carry what they might call decorative valve stems. They are usually just old truck style rubber or modern TPMS setups.
CTopher
Old 07-02-2024, 09:37 AM
Mr. Merk's Avatar
You gotta ask for the high pressure stems
part# 15-4559-2 from oreilly
Old 07-02-2024, 12:00 PM
