1984 3.2 no start (CHT sensor replacement didn’t fix)
Hi folks, I feel a bit dejected. I have a crank but no start issue with my ‘84, I tested the CHT sensor after consulting the forum and found the resistance to be erratic when the engine was warm. I replaced the sensor with the new two wire part to no avail. Any help from the brain trust would be greatly appreciated. Here‘s the full story:
I took the car one mile to the post office, when I got back in, it cranked but didn’t fire. After five minutes, it started right back up. Two days later, I drove the car two miles, parked it for 5 minutes, same thing except this time it took 20 minutes for it to start back up again. One day later I decided to drive it to my wrench. It didn’t make it, it stalled on the road. This time it needed a solid hour to start again (after the tow dropped it off at my place) Today I replaced the CHT sensor with a URO two wire sensor and the symptoms are the same. The car doesn’t event start when cold. What’s next? Crank position sensor? Flywheel sensor? I did swap DMEs a few times without success. Thanks for your help, Alex
1984 Carrera 3.2 Cabriolet |
Found this on the Forum, start here; 911 3.2 No-Start Troubleshooting
From step #2 above; Quote:
Dave Last edited by mysocal911; 07-09-2024 at 06:40 PM.. |
PCA Member since 1988
Evidently it's temperature related. These symptoms could also occur with a failing ignition coil. If you have a spare, swap it. If not, buy one. It's a good idea to have a backup coil in the frunk anyway. It gives you "umbrella effect"--if you have one, it won't rain. If you don't have one...
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Thanks guys, I ordered a coil and a noodle light, we’ll see.
