1988 G50 Release Fork updated??
So I now have the clutch out, and the release fork is part #950 116 712 3R. According the records I received with the car, the updated release fork installed with the last clutch job was 950 116 086 06, along with the shaft upgrade, etc. Does that mean I still have the original release fork, not the improved one? There are needle bearings in the casting. How can I tell if tranny was really machined for the upgrade? Also Bentley suggests on a G50, the flywheel should NOT be machined. My records also show that the flywheel has in fact been machined. Could that be why the clutch disengages right at the top of the pedal . This is getting complicated. I really don't want to buy a new flywheel.
Mark D
Old 02-26-2006, 03:20 PM
tig tig is offline
Decode it.
tig's Avatar
I have same question.
My 88 had the throwout bearing upgraded back in '97 when the engine was out for new valve seals (long story).
I've got the engine/transmission separated and when I pulled the clutch cross shaft out the needle bearings in the bushings fell out. I need to replace them or...?
How can I tell if I have the upgraded fork as well?
'88 Porsche 911 Coupe - Venetian Blau ║ '78 Mustard FJ40 "Uglina" ║ '87 BMW 529i "Maytag" ║ '87 BMW 535is "Vlad" ║ '85 BMW 528i S54 "Minerva"
Old 09-01-2024, 09:36 AM
lake wales fla
If the needle brgs are in the bell housing bores and the TOB fork has bushings than you have the updated parts. As far as resurfacing the New flywheel I have had 100’s of G50 flywheels resurfaced over the past 35+ years and never had any problems as long as you use a spring center disc and not the original style rubber hub disc.
Also in in general hydraulic clutches have a higher engagement point that only gets higher as the disc wears.
Richard
Old 09-01-2024, 11:09 AM
tig tig is offline
Decode it.
tig's Avatar
Richard
The needle bearings are inside the bushings on each end of the cross bar.
Here's my fork:
Old 09-01-2024, 11:17 AM
tig tig is offline
Decode it.
tig's Avatar
Lol
https://www.pelicanparts.com/More_Info2/95011671206.htm?bc=c
Old 09-01-2024, 11:18 AM
lake wales fla
LOL Better get that while it is still affordable 🤪
Old 09-01-2024, 11:58 AM
tig tig is offline
Decode it.
tig's Avatar
I've just confused myself...
When I originally read this, I must have read it wrong because I was thinking I needed the upgrade.
But now:
- The needle bearing holder was in the bellhousing.
- I have plastic bushings on the fork.
Thus it's the new kit. Right?
Old 09-02-2024, 12:32 PM
lake wales fla
But now:
Yes those are the updated parts.
Old 09-02-2024, 01:18 PM
tig tig is offline
Decode it.
tig's Avatar
Yay. Thank you.
Old 09-02-2024, 01:59 PM
