911SC Front Suspension Best Assembly Sequence
Anyone care to share logical assembly sequence. Starting with rack installation. I'm assembling by myself, no helper.
Old 09-06-2024, 07:59 AM
PCA Member since 1988
Put the steering rack in before you reinstall the cross member (if you removed it). Otherwise, the parts can be independently removed and replaced. I think you can even install the steering rack with the cross member in place, but it's easier if it's not in the way.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 09-06-2024, 01:06 PM
Hi Pete, that is what I came up with.
1. Steering Rack… What a bugger that was to install myself
2. Cross member
3. Control arms
4. Strut upper
5. Strut to Ball-Joint
6. Steering Tie-Rods
In torquing the upper Strut Nut, the washer with the keyway on the inside of the hole prevents the washer from rotating on the shaft, but nothing holds the washer/shaft from spinning while tightening. There is the outside slot, but it should have two slots to hold positively with an adjustable Face Spanner.
Old 09-06-2024, 03:32 PM
For the nut on top of the strut, do what the pro's do: Use an impact driver to get on or off.
Old 09-06-2024, 04:38 PM
Outside of Kalifornia we call it a Crescent wrench
Old 09-07-2024, 06:57 AM
I happen to be working on this same project myself. So I am asking this question out of ignorance not snarkyness.
Is there any reason to not bolt the rack and cross member together, then install as a unit?
Zach
1975 911S
Old 09-07-2024, 08:35 AM
No problem, I chose to assemble separately because of weight. I was doing it myself. It really doesn’t save time to assemble them together on the bench. It’s only two bolts.
Old 09-07-2024, 04:28 PM
