Correct torque for case nut when replacing alternator ground wire
I am going to replace the alternator ground wire. What is the correct torque for this case nut? See the picture below.
Old 09-09-2024, 02:32 PM
18
206 637 4071
Old 09-09-2024, 02:57 PM
Originally Posted by john walker's workshop View Post
18
Thanks!!
I'm assuming that is 18 pound / feet.
Old 09-09-2024, 03:02 PM
PCA Member since 1988
Yes. Or 24 N-m
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 09-09-2024, 04:12 PM
skinnerd's Avatar
Likely doesn't matter all that much at the top of the case. Dont sweat it. Gut 'n tite should be fine.
Old 09-10-2024, 08:47 PM
That worn out & rigid ground wire is identical to the one I pulled off my 3.0L this summer. Fresh new Porsche replacement wire from our host was inexpensive and flexible. Easy peasy.
912E-3.2ss
Old 09-10-2024, 09:04 PM
This cable attaches to the bottom stud on the outside of the deflector, correct?
Old 09-11-2024, 06:21 PM
On my 1984 Targa it was bolted directly to the alternator with the larger ground wire.
See the picture below, I've circled the wire in red where it attaches to the alternator with a larger ground wire.
I'm not sure that this is correct, it is just how mine was wired up and it worked fine.
Old 09-12-2024, 10:59 AM
FYI for anyone replacing the ground wire:
The alternator is grounded through several paths. The ground wire is obviously one path, however it also gets grounded through metal-to metal contact from the alternator to the fan housing, and then from the fan housing to the engine case. Therefore, whenever I have the alternator out, I make a point of cleaning and putting some grease on the contact points between the alternator and engine case . The last time I was in there, the brown ground wire insulation was cracking like the picture above, so I replaced it with a braided strap, much like the strap between the transmission and chassis, and between the chassis and the negative battery terminal, but smaller in cross-section. I think I salvaged it off a parts motorcycle.
Old 09-12-2024, 02:58 PM
