Correct torque for case nut when replacing alternator ground wire
I am going to replace the alternator ground wire. What is the correct torque for this case nut? See the picture below.
18
PCA Member since 1988
Yes. Or 24 N-m
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Likely doesn't matter all that much at the top of the case. Dont sweat it. Gut 'n tite should be fine.
That worn out & rigid ground wire is identical to the one I pulled off my 3.0L this summer. Fresh new Porsche replacement wire from our host was inexpensive and flexible. Easy peasy.
912E-3.2ss |
See the picture below, I've circled the wire in red where it attaches to the alternator with a larger ground wire. I'm not sure that this is correct, it is just how mine was wired up and it worked fine.
FYI for anyone replacing the ground wire:
The alternator is grounded through several paths. The ground wire is obviously one path, however it also gets grounded through metal-to metal contact from the alternator to the fan housing, and then from the fan housing to the engine case. Therefore, whenever I have the alternator out, I make a point of cleaning and putting some grease on the contact points between the alternator and engine case . The last time I was in there, the brown ground wire insulation was cracking like the picture above, so I replaced it with a braided strap, much like the strap between the transmission and chassis, and between the chassis and the negative battery terminal, but smaller in cross-section. I think I salvaged it off a parts motorcycle.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 09-12-2024 at 03:02 PM.. |
