'73 911 T Targa
Going from Petronix back to points - capacitor?
I’m switching back to points on my ‘73 Targa with Bosch 0231.169.XXX distributor and CDI.
I can’t remember what all I removed when I installed the Pertronix.
Would there have been a capacitor on the distributor?
Thanks for any help
Old 09-17-2024, 01:33 PM
No, the points act more like an on off switch, so the tiny round silver tube on old distributors is not used.
Rutager West
Old 09-17-2024, 01:51 PM
HarryD's Avatar
You need a capacitor with points if your do not have a CDI to help reduce the chance you will rapidly burn your points. Pertronix does not require a capacitor.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Last edited by HarryD; 09-17-2024 at 02:53 PM.. Reason: Correct need for Capacitor
Old 09-17-2024, 02:02 PM
Originally Posted by HarryD View Post
You need a capacitor with points to help reduce the chance you will rapidly burn your points. Pertronix does not require a capacitor.
Harry,
He has a CDI, does it still need a capacitor? My car didn’t have one.
Rutager West
Old 09-17-2024, 02:38 PM
HarryD's Avatar
I stand corrected.
Harry
2020 MB E350 4Matic
Old 09-17-2024, 02:53 PM
That's a small part of the reason. The real reason is that without a capacitor, the rise time of the coil primary voltage is too short when the points open,
resulting in a poor spark at the secondary winding to the distributor.
Dave
Old 09-17-2024, 06:17 PM
HarryD's Avatar
We are really saying the same thing as the consequence of not getting the energy to the coil, is an arc across the points.
The capacitor(condenser) absorbs the excess energy then releases this energy to the coil.
Harry
2020 MB E350 4Matic
Old 09-17-2024, 06:49 PM
'73 911 T Targa
It doesn’t take a lot, but I’m confused.
No capacitor as long as I have CDI, correct?
Old 09-17-2024, 07:26 PM
HarryD's Avatar
yep
Harry
2020 MB E350 4Matic
Old 09-17-2024, 07:49 PM
Technically, it's controls (defines) the dv/dt (rate of change of the primary voltage) based on the primary inductance.
Dave
Old 09-17-2024, 07:52 PM
It doesn't matter!
Dave
Old 09-17-2024, 07:54 PM
HarryD's Avatar
Errrr. Ummmm. Let’s not bring calculus into this!
Harry
2020 MB E350 4Matic
Old 09-17-2024, 07:59 PM
PCA Member since 1988
Re the purpose of the condenser (capacitor): it's a moot argument. Back when Charles Kettering first invented the "Kettering ignition system" he found that the points were burning too quickly, due to the arcing across the gap as the points opened. Knowing a few things about electricity, he added a capacitor, sized to absorb the current across the points until they opened far enough so that the spark would no longer jump and burn the points. dv/dt had nothing to do with this innovation. It was a practical adaptation to stop points from burning.
It also serendipitoulsy turned out that adding the capacitor created a resonant RCL circuit that increased the peak voltage of the coil. Win-win. Then comes the post hoc explanation of dv/dt.
Anyway, if you have the CDI box, the points don't carry significant current, so you don't need the capacitor. They only signal the CDI box.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 09-18-2024, 03:49 PM
You obviously don't understand the simple electronics circuit analysis of what happens when power is removed, e.g. points open,
from an inductor (ignition coil) without a capacitor or a voltage limiting device. The change in voltage versus time (dv/dt) becomes basically uncontrolled
and very high, potentially damaging the coil. That's the key purpose of the capacitor in the distributor of a simple points ignition system.
And as a result of the controlled dv/dt, it also reduces the burning of the points (arcing).
It's that simple!
Dave
Old 09-18-2024, 08:02 PM
You've got the actual development backwards.
Old 09-19-2024, 01:20 AM
@quickstep192, why are you going back to points away from Pertronix? Is it originality or something else?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-19-2024, 07:10 AM
'73 911 T Targa
Mostly just tinkering and trying to go back to an original base point. I’m chasing a mid-RPM miss.
I originally put in the Pertronix before I learned that the points in a CDI system are just a trigger.
I’ll see how it does with points and then maybe switch back.
Old 09-19-2024, 03:02 PM
