Carrera 3.2 - orientation of O2 sensor heat shield
What is the correct orientation for the O2 sensor heat shield on a 3.2 Carrera?
My thinking is that it should point at the cat to protect the sensor from heat coming off that cat as I have it set in the picture below.
Old 09-28-2024, 10:36 PM
ErrorMargin - your thinking makes sense. I'm no expert on this topic, but that's how I would position it myself.
Q: what Cat are you running here on your '84 3.2 Targa? It looks like aftermarket, and looks like it is rather recent --- with the barcode and QR code tag welded on. I see you're in SoCal, so assume this is a CARB approved cat?
My 83 SC (SoCal as well) may need a new cat, so keeping an eye out for CARB approved solutions.
Thanks!
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil
Old 09-29-2024, 07:31 AM
The PET has the shield protecting the sensor from road debris that could be kicked up by the tire.
Old 09-29-2024, 08:25 AM
My original "87 has the open end of the "U" shape facing the valve cover (rotate your shield 90 degrees clockwise).
Old 09-29-2024, 11:02 AM
I agree with Packin4.
Old 09-29-2024, 04:37 PM
My car recently passed smog (after a bit of work), so I guess it is CARB approved?
See below for a picture of the tag.
Let me know what you find about this.
The QR code resolves to this address (which is no longer registered to the company): http://www.deccats.com/part.php?product=PO82605
Old 09-30-2024, 10:45 AM
