Carrera 3.2 shroud broken at bolt mount point - how can I fix this?
The shroud on my 84 Targa is broken at one of the fan housing mount points, see the picture below.
How should I go about repairing this?
I'm not sure a simple fiberglass patch will provide enough strength for this mounting point.
Can I fill in the entire breach point with JB Weld and then drill a new hole through the JB Weld?
I am open to suggestions.
Old 09-28-2024, 10:47 PM
Just an idea, you might take a thin sheet of aluminum and JB weld that under the hole/broken area to function as base, then use some Ptex (it's a plastic rod that's used to fix scratches in ski bases, they sell them in both black and clear colors) to drip-melt into the gap. Then you could drill out the hole. With the Ptex, you should get an even mold throughout, and it should bond well with the shroud plastic - especially if you heat up the shroud plastic a little bit with a heat gun. After you drip-melt the plastic into the gap, you'll have to sand it down flat before you drill your hole. Just an idea. Good luck!
Old 09-28-2024, 11:07 PM
Senior Member
JB Weld a washer there.
Chris
1988 911 Carrera Targa (driving project started JAN 2022)
1970 911E - Long since gone
1972 911 Targa - gone
1987 911 Carrera - gone
Retired FA-18C Driver
Old 09-29-2024, 05:33 AM
Poke two holes stitch it together with wire, then cover it with 3m panel adhesive or other flexible epoxy.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 09-29-2024, 05:44 AM
The plug wire holder covers it. Sort of a non problem. Or use a wider washer under the bolt if no wire holder.
206 637 4071
Old 09-29-2024, 07:31 AM
PCA Member since 1988
^^ This.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 09-29-2024, 05:14 PM
Great suggestion on the wider washer. Problem solved!
This is a 1984 911. Is the Allen bolt correct for this position? Should it be a hex bolt?
Old 10-13-2024, 05:41 PM
Originally Posted by ErrorMargin View Post
...Is the Allen bolt correct for this position? Should it be a hex bolt?
I've looked at several 84s, a hex bolt is correct.
Old 10-27-2024, 05:33 PM
