cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
where does this wire connect to
I took the seats out to replace the covers. Everything with the seats works. The Automatic climate control does not work. There is this wire but I cant find where it connects to or what it does. I pulled up the automatic climate control box but there is nothing to connect it to. I dont see anything under the seat either.
The wire looks to run along the seat rail and would be just long enough for the automatic control box. Again, nothing in there to connect to. there is no power to the wire and jumping it (crossing it) does nothing.
Thanks,
Chris
89 Carrera
Old 10-16-2024, 09:14 AM
E Sully's Avatar
Could it be for the seat belt buzzer?
Ed
1973.5 T
Old 10-16-2024, 10:18 AM
proporsche's Avatar
looks like for your heater control box sensor connector...
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 10-16-2024, 12:16 PM
cmcfaul's Avatar
Ivan
Thanks Ivan, where does it connect, specifically?
Chris.
Old 10-16-2024, 01:03 PM
proporsche's Avatar
well looks like you have semi automatic control unit --remove the 4 screws which hold the body down and inside should be male connector to plug it in..
no 10 here
https://www.eurospares.com/Porsche/911/911_(1984)/PartDiagrams/908-000/HEATING_SYSTEM_1?srsltid=AfmBOorKSKNHOYinkg-UGPY3ZSTNbNrRTqvo5yyAkiLAvdr4lb6Gl3g9
Old 10-16-2024, 01:25 PM
cmcfaul's Avatar
I have the 4 screws off and the inside of the control moduel visable. I see no place it connects to. Its the first place I looked.
Many thsnks,
Chris
Old 10-16-2024, 02:02 PM
proporsche's Avatar
i wonder if it is just an option for a full automatic heater wire set up, then?
ivan
Old 10-16-2024, 02:35 PM
cmcfaul's Avatar
Many thsnks,
Chris
proporsche's Avatar
as i suspected yours is semi automatic unit .If you would have fully auto unit it would plug here
Old 10-16-2024, 11:04 PM
cmcfaul's Avatar
Many thanks,
Al least i know thats not the issue.
Chris
Old 10-17-2024, 04:47 AM
cmcfaul's Avatar
figured it out.
Put it back together (ignoring the random wire). Checked the fuesbox and one of the relays was loose. I replaced the hood shocks while the seats were being recovered and must have knocked it loose. pushed it back in and everything works as before.
thanks again for your help.. Love this group.
Chris
89 Carrera
Old 10-17-2024, 10:23 AM
