where does this wire connect to
I took the seats out to replace the covers. Everything with the seats works. The Automatic climate control does not work. There is this wire but I cant find where it connects to or what it does. I pulled up the automatic climate control box but there is nothing to connect it to. I dont see anything under the seat either.
The wire looks to run along the seat rail and would be just long enough for the automatic control box. Again, nothing in there to connect to. there is no power to the wire and jumping it (crossing it) does nothing. Thanks, Chris 89 Carrera
Could it be for the seat belt buzzer?
Ed 1973.5 T |
looks like for your heater control box sensor connector...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
well looks like you have semi automatic control unit --remove the 4 screws which hold the body down and inside should be male connector to plug it in..
no 10 here https://www.eurospares.com/Porsche/911/911_(1984)/PartDiagrams/908-000/HEATING_SYSTEM_1?srsltid=AfmBOorKSKNHOYinkg-UGPY3ZSTNbNrRTqvo5yyAkiLAvdr4lb6Gl3g9
I have the 4 screws off and the inside of the control moduel visable. I see no place it connects to. Its the first place I looked.
Many thsnks, Chris |
i wonder if it is just an option for a full automatic heater wire set up, then?
ivan
as i suspected yours is semi automatic unit .If you would have fully auto unit it would plug here
Many thanks,
Al least i know thats not the issue. Chris |
figured it out.
Put it back together (ignoring the random wire). Checked the fuesbox and one of the relays was loose. I replaced the hood shocks while the seats were being recovered and must have knocked it loose. pushed it back in and everything works as before. thanks again for your help.. Love this group. Chris 89 Carrera |
