cruise Control not working
89 Carrera.
Cruise Control worked a year ago. Not sure why not now. The cable appears to be the right tightness. No Light on the dash to indicate it's on. Any likely causes I should check out. I drive every day on an HOV road. Its easy to hit 90 without paying attention as there are few cars on the road. Thanks, Chris |
Check the switch to the right of the pedal cluster. It is inside the hump.
Clutch Pedal out should close the switch and allow the CC to engage. When the pedal is pushed in a small amount, it opens the switch to disengage the CC. Also check the two vacuum line on the forward end of the CC Pod. Last edited by porschedude996; 04-25-2023 at 09:58 AM.. |
First off, the Bentley manual is totally wrong on the trouble shooting tests.
Most likely, it is the main module. It is easy to get to in the trunk. Remove it, and send it to one of the many rebuilders. I think Timmy does them. It is the same unit that Mercedes used. Do a search for cruise control on the site, and you will find multiple threads about it. On my 85 there is no light at all on the dash for the cruise, I did not know there was a light one the dash for later model 3.2s 911s.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
No instrument light for my 87 Targa. I had my CC module rebuilt and found a disconnected vacuum line during suspension refresh engine drop/install.
Northeast Ohio 1987 Porsche 911 Targa 1966 VW Beetle, 6V |
Your 89 is a 964 platform, right?? Many electronic upgrades. Cruise may work much differently.
Or not at all, i.e. analog vs digital!
Dave |
Mine worked fine every time I used it. Did some detail work in the engine bay and it didn't work anymore. Poked around for what I may have disturbed, etc., then pulled the bullet fuse and one of the end caps fell off (cracked, not burned). Replaced the fuse and it's been fine since.
My 88 has worked great for years in over 10 years of daily use. I have had to replace the Bowden cable in the engine compartment once and carry a spare in the car.
Good luck.
2002 GMC Yukon SLE - 4AT - Purchased New in 2002 1988 911 Cab - 5MT - Purchased Used in 2005 2008 Cayman - 5MT - Purchased New in 2007 2014 911/50 - #1173 - 7MT - Purchased CPO in 2014 2019 Macan S - 7PDK - Euro Delivery/New in July 2019 |
After reading these posts is jiggled the clutch petal while driving and the CC started working. Guess I have a bad switch.
Many Thanks everyone! Chris 89 Carrera |
Find a skinny yoga instructor to get their head and hands down there to adjust it.
As an old fat man myself, it is a very tight fit and really hard to see with bifocals down in that area. It is not fun.
Also, still no light on the dash. Quote:
SWB 912 - G50 Carrera - 986 Boxster - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo Workshop Coordinator at Ehrlich Motorwerks instagram.com/patrickossenkop ehrlichmotorwerks.com |
Call 911
Mine became intermittent but using some contact cleaner spray in the steering column stalk switch seems to have cured the problem.
Dave Kirk My Porsche restoreth my soul. |
We fixed one last week that was due to no contact with the clutch switch. We adjusted the switch but in hindsight probably could have just adjusted the bracket in the tunnel by loosening the two 10mm nuts.
Also pondering if there this is an early symptom of a failing master cylinder not fully returning the pedal the last 5%.
