Side Window Seal Question
I replaced the inner and outer window track seals on my '85 cab; unfortunately the improved seals pulled the glass out of the channel (not all that surprised based on the quality of the window regulator work done prior). I have new window track seals... what adhesive should I use? is it the Porsche Adhesive kit (000-043-305-35 - https://www.pelicanparts.com/More_Info/00004330535.htm?pn=00004330535&KeepHeader=Y&SVSVSI=0582 ) or is there some other product recommended?
Thanks in advance! |
Behind the Sun
Honestly any good contact cement will do.
I don't know what it's sold in Spain I'm sure the Porsche glue is great Just be sure there are no oil or grease residue |
Thanks! |
Behind the Sun
220 euros. Damn
I don't blame you |
3m super weatherstrip adhesive, i am sure there is a wurths version. Are you talking about the glass to track on the regulator?
Yes - glass to track on regulator. As mentioned above, unfortunately 3M is hard/expensive to get, but I can get Petec out of Germany via Amazon. Oddly, Wurth is not on Amazon Spain, and expensive to ship otherwise.
