kellzey's Avatar
Need help finding this muffler
Looking for the "wider" sport muffler as in this 914-6-GT picture.
Not that the exhaust tips are wider apart and larger in diameter than this commonly availlable sport muffler...
Any leads?
Qarl
Old 06-28-2003, 09:17 PM
TYPE 901/05's Avatar
I want one too...
Read through this thread for some contacts and ideas. It nearly answers your question.
When I was looking down that road, I remember that the internal baffels did not allow the width that you are wanting. I say make your own. Then copy me with the works.
Shawn.
with s cams and carbs
Old 06-29-2003, 02:35 AM
gumba's Avatar
I just finished converting a stock muffler into a sport muffler. I can post some shots showing the inside of the muffler with baffles I welded in. You could mount the exhaust tips as wide as the inlet pipes if you wanted. The muffler wouldn't muffler anything. I welded in some more baffles because I want it quieter than the sport muffler. I moved the tips as close together as I could. Won't know how it sounds for a few weeks until I get the motor back in.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 06-29-2003, 08:33 AM
ted ted is online now
likes to left foot brake.
ted's Avatar
is this the same muffler?
http://www.911t.org/WklyReprint/modified_muffler.htm
Old 06-29-2003, 10:04 AM
kellzey's Avatar
I don't think that's the same muffler. I'm sure you could follow the same logic and build a duplicate the same way.
I'm not sure how the factor 911ST or 914-6-GT mufflers were baffled internally.
THAT would be nice to figure out.
Qarl
Old 06-29-2003, 10:11 AM
gumba's Avatar
If you look where the inlet pipes are located relative to where the two new exite pipes are you'll notice there is no baffling. It seems to me the majority of the exhaust will go straight from the inlets to the outlets and some of the exhause will circulate around.
Harold
Old 06-29-2003, 03:57 PM
kellzey's Avatar
I'm sure that these mufflers are baffled somewhat different internally.
Qarl
Old 06-29-2003, 09:23 PM
skinnerd's Avatar
I'd just build your own. This is a "Pressler" sport exhaust that was built for me about 10 years ago. He may still be around the west coast somewhere. You could place the tips just about anywhere.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 06-30-2003, 07:58 AM
Luke Hudson's Avatar
There's a chap that appears to be selling what you're after on eBay:
see eBay Item number: 2421576353 there's 3 days left.
With my basic german I can tell you that the guy has made this exhaust himself and it cost him 350 Euro's to make. The case and pipes are stainless steel. The pipes extend 12cm from the case and have an external diameter of 54mm, conical steel baffles are provided to change the pitch of the exhast and back presure. Exhaust has only travelled 20km's to test its sound.
Might be worth a look (although shipping to the states may be extortionate!)
Aubergine 1972 911 2.4E - Gone but not forgotton
HP2S #1185 - Ain't she purty
Resident @ www.ddk-online.com
Old 07-02-2003, 06:25 AM
Luke, how bout a pic of the purple monster!!
Dennis H. 72 911E 2.7 RS stuff
72 911T with a 2.7(Sold 5-13-2011)
2012 Kona Blue Metallic Mustang GT Convertible 6spd
67 Mustang coupe future SVRA group 6 car
63 Falcon hardtop 302/4spd
Old 07-02-2003, 06:36 AM
Once I step out of the 35mmm dark ages, I'll post some shots.
Trust me, she's pretty!
Old 07-02-2003, 06:44 AM
