GTT GTT is online now
Help with Engine compartment light wiring connection
Can someone shed some light for me on how the wiring harness plugs into the engine compartment light housing? I'm reassembling a car someone else took apart and cannot figure out how the wires are suppose to connect to the housing. Are they supposed to somehow plug into the two little brass fittings on the backside of the housing?
Old 01-01-2025, 08:05 AM
group911@aol.co's Avatar
On the other side of the fixture, there are posts that those 2 wires screw into.
Should be pretty evident which one is the ground side
Thanks,
Bob
group911@aol.com
Old 01-01-2025, 08:30 AM
Thank you! Now I see the housing comes off the top. Appreciate the help!
Old 01-01-2025, 09:25 AM
I’ll be doing this soon on my car, please post pictures of how it connects and how the wire is routes from the light down to the point where it joins the main wire harness… I’m curious how the harness is attached to the deck lid and how it transitions to the body.
Old 01-01-2025, 09:29 AM
This is how I ended out routing the harness, but since I didn't take it apart, I'm not claiming to be an expert. I saw a couple pictures on another thread so I think this is correct.
Old 01-01-2025, 01:23 PM
That looks about right. Just make sure the loom doesn't go through any metal holes that aren't protected by a grommet.
Don't forget that the park lights need to be on for the light to work.
It should also turn off when the cover is rolled closed.
Old 01-01-2025, 01:37 PM
This is how I ended out routing the harness…
Can you show how it routes from the deck lid into the engine bay, and how it travels in the engine bay down to the wire harness bundle?
Old 01-02-2025, 07:21 AM
Mine goes from the light toward the back lip of the deck, then travels down the left side as you are looking into the compartment and is attached to the left hinge before meeting the rest of the loom. It is held in place with metal clips.
Old 01-03-2025, 04:25 AM
Does that light ground to the decklid, or ground wire back to somewhere else?
1982 911SC
Old 01-03-2025, 05:27 AM
Brown is ground
Old 01-03-2025, 05:40 AM
I am not sure where the brown ground wire on the light housing attaches at the other end. I didn't remove the whole harness - the housing was just disconnected from the light pig tail when I got it. Sorry I'm not much help.
Old 01-03-2025, 05:42 AM
ROW '78 911 Targa
timmy2's Avatar
Grey connects to a WECO single connector at the 6 pin tail light drivers side.
Brown goes to the ground stud behind the fuel filter.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 01-03-2025, 06:30 AM
Thanks, that is just what I needed!
Old 01-03-2025, 08:31 AM
