Nice job, JW. Where did you get the leather dye and conditioner?
Side mirrors all finished up and reinstalled with new gaskets.
http://forums.pelicanparts.com/uploa...1742738234.jpg http://forums.pelicanparts.com/uploa...1742738234.jpg http://forums.pelicanparts.com/uploa...1742738234.jpg http://forums.pelicanparts.com/uploa...1742738234.jpg http://forums.pelicanparts.com/uploa...1742738234.jpg |
Started work on the rear end today. Removed brake calipers, rotors, and bolts for spring plate. I foresee a battle getting these TB out.
http://forums.pelicanparts.com/uploa...1742738532.jpg http://forums.pelicanparts.com/uploa...1742738532.jpg |
Hopefully the torsion bars won’t put up much of a fight. My 46 yr old original tb’s pulled out with minimal/ avg effort in my ‘76. Had never done this before then... You gotta this.
The amount of dirt and tar caked on was a disaster, but managed to clean the wheel well. Still plenty to replace and get cleaned, but it’s starting to take shape rather quickly. Upgrading to 29mm tb with rennline adjustable spring plate. http://forums.pelicanparts.com/uploa...1742786733.jpg http://forums.pelicanparts.com/uploa...1742786733.jpg http://forums.pelicanparts.com/uploa...1742786733.jpg |
Was removing stuff in the engine bay to get better clearance for the rear strut mount bolts. Old sound pad was toast so I threw that out.
Also found a pool of oil in my air box. I’ve only driven the car once, which was the day I purchased it. As I was pulling into the driveway it started to smoke heavily out of the exhaust. I assume when the previous owner had an oil change done prior to selling, the shop overfilled it. Do we agree that’s the most logical explanation? http://forums.pelicanparts.com/uploa...1743221493.jpg http://forums.pelicanparts.com/uploa...1743221125.jpg http://forums.pelicanparts.com/uploa...1743221567.jpg |
Beautiful car! |
They look great BTW! |
Can you explain the process to disassemble the side mirrors?
Thanks. Quote:
https://forums.pelicanparts.com/porsche-911-technical-forum/177946-sc-door-mirror-removal.html |
Nice work, did you get Clyde's regular Dark Blue dye? Or was it a special order color? It looks great
Decided to ditch the side amber markers in favor of the rubber trim. Looks alot better in my opinion
http://forums.pelicanparts.com/uploa...1744262387.jpg |
Took out 90% of the heater system to gain better access to the rear strut top mounts, so figured I might as well backdate my system for a cleaner look. Also started the tedious process of deep cleaning/detailing a little as I go. It’s a mess, so seeing any progress in the engine bay is encouraging.
http://forums.pelicanparts.com/uploa...1744505390.jpg http://forums.pelicanparts.com/uploa...1744505409.jpg http://forums.pelicanparts.com/uploa...1744505409.jpg http://forums.pelicanparts.com/uploa...1744505409.jpg |
Little more progress cleaning the engine bay and installing the backdate system. I have to say I’m surprised how well it’s cleaned up, better than I expected. Now the fan sticks out like a sore thumb.
Also got my front spindles back from elephant racing. Raised 30mm, shallow washer seal, Bilstein sport inserts, bump steer kit and reinforced gussets. http://forums.pelicanparts.com/uploa...1744750268.jpg http://forums.pelicanparts.com/uploa...1744750268.jpg http://forums.pelicanparts.com/uploa...1744750268.jpg http://forums.pelicanparts.com/uploa...1744750268.jpg |
Let me guess--elbow grease? ;)
You could definitely be my neighbor. I like detailing engine bays and chassis components. Your photos are just right too.
Beuatifull engine bay !! Pictures of course don't do justice to all the work it takes to get that result ..
| All times are GMT -8. The time now is 05:30 PM. |
