dictoresno's Avatar
Originally Posted by jwolfe View Post
Made some progress on installing my Numeric Racing shifter. Removal of the old one is pretty easy, only difficult part is lifting the center console without disconnecting the wire harness. I managed to work around it.
I still need to install the coupler before making any comments on how it feels. Simply replacing the shifter though has already removed almost all the slop, but definitely needs some aligning as a few gears are hard to get through. Looks great!!
ok I think I found my next upgrade for sure. love it!
1986 Porsche 911 Carrera 3.2
Old 04-15-2025, 09:05 PM
More incremental progress as I aim to have the car back together by the first week of May.
I have AC, but the car didn’t come with a compressor. So until I buy one and put the system back together I figured might as well remove the condenser. This gained access to remove the rear grille, clean underneath and give it a fresh coat of paint.
Also removed the rear lower valence as it had some scuffs and a dent. Prepped and repainted, along with various other parts waiting to be installed.
1983 911sc - Slate Blue Metallic
IG: @Wolfesgarage
Old 04-20-2025, 06:43 PM
Rear before and after
IG: @Wolfesgarage
Old 04-29-2025, 06:05 AM
Well done jwolfe! Beautiful car, great color both ext/int.
I see that on the rears you swapped out the green HD Bilsteins for the yellow Sports or Performance. Did you also upgrade to thicker TB's and rear sway bars?
For my 83 SC (silver) I am looking to replace the green Bilsteins on all 4 corners. Wondering if switching to the yellow's would be a good idea.
Cheers!
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil
Old 04-29-2025, 08:06 AM
Cheers!
Hey! I opted for 29mm tb in the rear and 22mm up front. Haven’t driven on it but based on other threads it seems that’s a drivable setup that leans a little stiffer which is what I need for how low I’ll be. Sway bars are stock for now.
I opted for koni rears because of the damper adjustability. I was going to run them up front as well but didn’t realize I have Bilstein spindles (they were black from dirt so I assumed they were boge lol), since they wouldn’t fit, I went for Bilstein sports up front.
IG: @Wolfesgarage
Old 04-29-2025, 02:54 PM
Thanks for sharing your thinking process on the upgrades. Very interested to see how it turns out for you, how you like it. Will keep an eye on this thread.
Didn't realize you had Koni's at the rear. I thought that yellow shocks indicate Bilstein Sports.
Good luck next steps --- it's looking really good! I've learned a bit from your thread --- on the leather reconditioning, will have to try it!
Old 04-30-2025, 02:44 PM
Engine bay is back together for the most part. Very happy with the difference some effort in cleaning can do. Will refinish the fan and shroud next to really bring it all together.
IG: @Wolfesgarage
Old 05-04-2025, 06:36 PM
A reminder of where it started
IG: @Wolfesgarage
Old 05-04-2025, 06:44 PM
Scored a pair of 16x9 Bbs rs from Carlisle last week. Also started the process of redoing my parcel shelf. The leather on the seat is in good shape but the shelf itself needed new fabric. Now I just need to source a blue leather match.
IG: @Wolfesgarage
Old 05-12-2025, 06:51 PM
Rear parcel shelf is all finished up. I managed to find a leather that matches better than the original one and re-wrapping it was fairly straightforward. Went ahead and updated my speakers/grills, and deleted the seatbelts for a cleaner look. Very happy
IG: @Wolfesgarage
Old 06-04-2025, 10:28 AM
Decided to reverse my windshield wipers today. I swapped the 2 wiper arms, and bent the one the other way for a more tucked position.
IG: @Wolfesgarage
Old 06-18-2025, 07:13 PM
Nice build. Following
Chiffon 1983 911sc Targa
IG: ianmcallisterb
Old 06-23-2025, 06:23 PM
Hey can you drop the link or part # for the driver side heat backdate plate? the one I ordered from our host fits like garbage on my '83.
'83 911SC - Rubinrot Metallic
IG: @911.sc.83
Old 06-23-2025, 06:48 PM
I wish I could, but the kit I bought also fit so terribly. I used thin window seal foam to fill in all the gaps and get a somewhat air-tight duct. it required so much warping, and still didn’t fit well
IG: @Wolfesgarage
Old 06-24-2025, 01:19 PM
Still needs an alignment, but it’s finally on the ground and driving around. I just got it back from the mechanic where a laundry list of seals and air leaks were addressed to get it running top notch. Triangle of death was my worst leak that couldn’t be ignored. Mechanic also found 1 broken head stud, but I’m just going to send it for now and worry about that at a later time. It holds compression and doesn’t leak any oil so it’ll be fine.
IG: @Wolfesgarage
Old 06-26-2025, 05:45 PM
Since people will probably ask: Wheel specs are 16x8 +10 up front and rears are 16x9 +15, and 25mm spacers.
IG: @Wolfesgarage
Old 06-26-2025, 05:47 PM
Looks great - look forward to driving impressions! I respect your attention to detail. That’s a lot of hard work in itself. You’ve made an avg SC look phenomenal.
912E-3.2ss
Old 06-28-2025, 04:00 AM
Drove the car around a little more and noticed some smoking. Got home and saw a decent amount of oil dripping from the top back of the engine. Decided to clean everything to find the source, and it was very clearly the triangle of death. Dropped the car off to my mechanic and had laundry list of leaks taken care of, as well as some vacuum leaks which explained my stalling issues when stopping. Now she’s running strong!
Mechanic did discover 1 broken head stud, but I am just going to drive it and enjoy the summer. I’m not worried about it and can address it later down the line.
IG: @Wolfesgarage
Old 07-03-2025, 06:49 PM
Installed some Tarett camber plates up front for more adjustability right before my alignment. All dialed in and ready to drive
IG: @Wolfesgarage
Old 07-24-2025, 07:11 PM
Gorgeous car , tasteful mods , great results !!
Old 07-24-2025, 10:04 PM
