Originally Posted by jwolfe View Post
Hey jwolfe really nice work with all these projects. I've been chipping away on my 83SC in a similar fashion
what have you done here with that new engine bay sound pad?
1983 911SC - Helibronze Metallic L966
Old 07-26-2025, 03:15 AM
Google “Classic VW Bugs” and you’ll see a guy who makes them. Much nicer looking in my opinion than the oem one.
Sent my wheels off to get refinished. Doing the rsr colorway with a slightly darker silver and polished lip edge. Snapped some progress photos.
Also ordered some custom made floor mats for my navy interior. German wool square weave with leather trim.
1983 911sc - Slate Blue Metallic
IG: @Wolfesgarage
Old 08-12-2025, 07:58 PM
froggert's Avatar
Love the dark silver. Is it matte, too?
Old 08-15-2025, 08:23 AM
Thanks, it’s a satin. So the black and silver will be satin.
Decided to refresh my rear rail light lenses. The new ones make a big difference.
No more scratching, faded black trim, or sun faded color loss. Here’s a before and after.
M
IG: @Wolfesgarage
Old 08-15-2025, 10:42 AM
PCA Member since 1988
Nice rug under your car. I hope it doesn't leak oil!
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-15-2025, 11:51 PM
Yo, jwolfe!! I like your thread and your car! But did ya know that's a handwoven "American Sarouk" Persian carpet under your engine? Probably C.1945-1950, they do fetch money at auctions. And......they surely don't make them like that anymore! I inherited 2 of those from my grandparents/parents. They are not disposable, like the machine-made ones are. Just a tip......
Old 08-16-2025, 02:00 PM
I leave a piece of cardboard under the engine bay if any leaks appear so the carpet is protected enough. I snagged it from an estate sale, thanks for the info.
Wheels are almost ready to be mounted. Should change the whole look of the car. Also throwing on some new lug nuts to bring it all together.
IG: @Wolfesgarage
Old 08-20-2025, 02:10 PM
I’ve been enjoying the car finally so I took a little break from posting. Here she is all together and back on the ground with the newly finished wheels. Couldn’t be happier with how it all turned out.
IG: @Wolfesgarage
Old 09-10-2025, 09:41 AM
Best looking G body. Killed it.
Standard Competition Motors, Berkeley Heights, NJ | Maxxecu engine management and Plex tuning calibration specialist and supplier | chassis dyno tuning and calibration consultations
http://www.instagram.com/standard_competition_motors
Old 09-10-2025, 09:54 AM
Bill Verburg's Avatar
Since people will probably ask: Wheel specs are 16x8 +10 up front and rears are 16x9 +15, and 25mm spacers.
earlier in the thread you mentioned 951 8s in front, these have ET23.3
here you mention 8x16 ET10, which are likely 911 and would have ET10.6
I'm curious as to which is used on your front wheels also what tires?
Bill Verburg
Old 09-10-2025, 02:34 PM
Thanks a lot! I appreciate it.
I originally had the 951 8’s up front but quickly realized I could likely squeeze the 16x8 +10 so that’s what you’re seeing in all the recent photos. I’m running 195/50 Bridgestone re71rs. They run very wide so it’s more like a 215/50 in reality.
IG: @Wolfesgarage
Old 09-10-2025, 03:41 PM
Registered Minimalist
75 911s's Avatar
Nice build!
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 09-12-2025, 05:10 AM
Pretty car !!!!
Old 09-12-2025, 07:19 AM
Your 944 was awesome and the 911 is even better!!!
https://forums.pelicanparts.com/porsche-911-technical-forum/1126782-1979-911-sc-silver-bullet.html#post11803066
@MattRyan318
Old 09-12-2025, 09:12 AM
I’ve been enjoying the car, taking it out every week to an event or cc of some sort. It’s been a blast. Also got a full detail/paint correction to really reduce swirling.
IG: @Wolfesgarage
Old 10-04-2025, 06:51 PM
Gorgeous 83. Been following. My 83 is a cab I started playing with 6 years ago. Still does not look as nice as yours but she is fun to drive.
Did you ever get this bracket off? Took me forever:
You mentioned getting the fan refinished. I highly recommend Cerakote. Five years later mine still looks new:
Doing my suspension this year and will be referencing your build. Thanks for the inspiration!
Regards
Old 10-06-2025, 05:59 AM
Regards
Thanks! I think I just left it on since I do want to reinstall my ac at some point in the future. Previous owner took out the compressor.
IG: @Wolfesgarage
Old 10-06-2025, 09:17 PM
Found a good deal on a used Dansk exhaust locally. Old one has clearly never been taken off before as every single bolt needed to be cut out.
IG: @Wolfesgarage
Old 11-08-2025, 08:51 PM
Big compliment, good work!
Old 11-08-2025, 10:27 PM
