30 to 3.2 SS CIS
In the process of assembling Motorsport P&C
For CIS. Need to confirm the orientation of the piston. Attached is a pic of cylinder 6, the high part of the dome is toward the flywheel while 1-3 is toward the pulley. Is this the proper orientation of the pistons? Thanks,
Rusty
Maybe a photo uploaded
Old 06-30-2023, 09:06 AM
PCA Member since 1988
I don't see a photo. The dome goes away from the spark plug.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-30-2023, 11:21 PM
CIS Piston Orientation Guide…….
Rusty,
This is how I remember the correct CIS piston orientation. Looking directly at the top of the cylinder/s, close your left fist (this represents the high spot on the piston) and point out your right fore finger (this represents spark plug direction towards the low spot) You must be facing the top of the cylinders when you do this inspection.
Left hand make a fist (high spot) and right hand point your fore finger out. Hope this helps you.
Tony
Old 07-01-2023, 04:29 AM
1,2,3 side
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 07-01-2023, 06:12 AM
Thanks guys, I think I got it right on 1-3 and had to turn the pistons so the high part of the dome faced the pulley. For whatever reason my photos wouldn’t upload.
Happy 4th!
Old 07-01-2023, 06:42 AM
Mark Salvetti's Avatar
What mods are you making to the CIS? Different fuel distributor?
Thanks!
Mark
1979 911SC Targa
Old 07-01-2023, 08:22 AM
Mark, same fuel distributor and intakes. Just changing the cams to 964 profile
Old 07-01-2023, 09:33 AM
al lkosmal's Avatar
Piston orientation
RGruppe #669
http://www.x-faktory.com/
Old 07-01-2023, 09:51 AM
Rusty
Exactly which pistons are you using?
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 07-02-2023, 02:01 AM
Mahle Motorsport
PS98-015 piston and cylinder set for CIS.
Old 07-02-2023, 07:06 AM
Mahle Motorsport
Can you post a picture?
Always learning.
Old 07-04-2023, 11:49 AM
Not the best photos but I believe what is being said the low part of the dome should go under the spark plug.
Will post a picture of the piston alone tomorrow afternoon
Thanks and hope everyone had a great 4rh.
Old 07-04-2023, 05:30 PM
Just wondering if you snapped pics of the final correct orientation for this Mahle kit?
I am nearing this stage and I would love to confirm orientation.
Thanks for the time
Chris
Old 01-26-2025, 07:06 AM
Thanks for the time
Chris
Chris I’ll take a few picture Monday. Just starting another rebuild with the 3.2SS and post them.
Rusty
Old 01-26-2025, 01:38 PM
Thanks Rusty, hopefully it looks like this on 4,5&6 ha.
Old 01-26-2025, 03:41 PM
Joe Engineer has some great pics: https://******************/porsche-911-heads-and-cam-towers/
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings)
Dynamic CR calculator: https://dcr.questionable.services/
Gear Ratio (Speed @ RPM) calc: https://ratio.questionable.services/
Old 01-27-2025, 06:21 AM
Silver lock thanks for that he does have excellent pics. Looks like I got mine in there correct on 4,5&6
Old 01-27-2025, 12:12 PM
