Clutch pedal raises under hard acceleration
anyone experience this?
i noticed when i get the car up to higher revs under hard acceleration, the clutch pedal pushes forward.
i step on it and it goes back down and disengages like normal but im guessing i need that fixed!!?
any ideas?
Old 08-16-2025, 05:54 AM
and just what Porsche do you have?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 08-16-2025, 07:41 AM
Is this due to a walking crank - excessive crank end play??
I had the exact same thing happen in my Chevy Stovebolt 261.... probably the furthest thing from a Porsche engine that is still out there!
Dave
1985 Porsche 911 Carerra Coupe 3.2 to 3.4L
PCA Member- Sacramento Valley region
Old 08-16-2025, 09:48 AM
Kevin Stewart's Avatar
Check your transmission and motor mounts.
Old 08-16-2025, 10:18 AM
i have a 84 3.2 Cab
Old 08-16-2025, 07:44 PM
will do
thanks
Old 08-16-2025, 07:45 PM
how would that affect it though?
i think the clutch is cable operated and behind the driver..
the pedal pushes out towards you..
Old 08-18-2025, 08:17 PM
that's it?
not interesting enough??
lol
Old 08-22-2025, 08:02 PM
84 911 Cab.you were going to add something?
Old 08-22-2025, 08:04 PM
Anytime a motor moves ie bad motor mounts etc. it usually will put pressure somewhere else, or your chassis could be flexing.
Old 08-22-2025, 09:13 PM
Still here
pmax's Avatar
Did you check the mounts ?
Old 08-24-2025, 04:03 PM
Physics. If the pedal comes up the throw our bearing is coming forward. Could be mounts could be tranny.
Old 08-24-2025, 04:32 PM
i don't get it though, isn't my pedal cable actuated?
i'll have my mechanic check it out
thanks
Old 08-26-2025, 05:20 AM
thanks
Yes, your clutch is cable actuated. The problem starts with how the cable housing is attached to the car. At the forward end, the housing is anchored to the body of the car. At the aft end it is anchored to the transmission and engine assembly. That transmission and engine assembly is mounted to the body of the car via four rubber mounts. They are rubber so that they can absorb vibration and not transmit much to the body of the car.
When these rubber mounts wear, they allow for excessive movement between the transmission and engine assembly and the body of the car. With the clutch cable housing spanning the two, it gets alternately stretched and compressed. It's designed to do this all the time, without you noticing, since those rubber mounts will always allow for movement. It's when that movement becomes excessive that you see and feel it in the clutch pedal.
That's why they are telling you to check those engine mounts
Old 08-26-2025, 07:44 AM
Awesome
thank you for the explanation.
now i know why.
appreciate the knowledge.
Old 08-26-2025, 04:42 PM
