Good videos from that YouTube channel. They have some that cover racing in Norway or Sweden that are really good too... Erik |
https://youtu.be/fqmc7dtzwmc?si=lqeCIh_Lm2Fne1O- |
This was in the parking lot at Eurofest in Greenville, SC. Cooler than anything in the actual show. I asked them to try to find the owner to tell him his lights were on.
http://forums.pelicanparts.com/uploa...1744556805.jpg http://forums.pelicanparts.com/uploa...1744556805.jpg |
In case anyone hasn't seen it, here's the build thread I started for the next member of the rally 911 family... https://forums.pelicanparts.com/porsche-911-technical-forum/1176190-build-thread-champagne-dirt.html#post12446093 |
I'll be damned, a Werks Gruppe build!
https://bringatrailer.com/listing/1982-porsche-911sc-176/ |
My version of a rally car. 69T I built for myself
1969 911 T Brought to you by Supertec The car is a numbers matching example of a very nice Porsche street rod. Clean current California title.131,000 miles before restoration The paint is high quality bare metal color change. (Don Emory) The paint is PPG Acrylic Urethane. The color is called Cool Vanilla. It is very similar to Porsches Light Ivory. The bumpers are 73. All of the chrome has been blacked out and most rubber is new. The chassis is rust free with signs of professional rust repair. The entire chassis is coated with Worth SKS undercoat The engine is a 2.45 liter twin plug with DC Mod “S” cam and 9.5:1 compression. The entire engine was balance to 1gram. The case has CaseSavers, oil by-pass mod, 3.2 Carrera pump, line bore and oil squirters. The 2.4 (70.4 mm) crank was magged, polished and cross drilled. The pistons are JE 9.5:1 forged racing pistons in new 86mm Biral barrels. The rods were rebuilt new bolts & 12 point flanged nuts. The heads are 2.7 liter with 36mm intake ports and machined for twin plugs. Phosphorus /bronze valve guides and new oversized valves (47, 41) were installed. The valve springs are Supertec 240. The head studs are of course Supertec. The cams are 4 journal billets, DC Mod “S” for great mid range to high RPM performance. 10,000 RPM tack with an 8000 RPM red line. Carrera chain tensioners, chains, ramps with Supertec tensioner arms were installed Rockers are rebuilt with Teflon lined bushing and Rockwell tested to guarantee cam compatibility. Shafts were polished. The carburetors are 40mm Webers completely remanufactured. PMO manifolds. A Supertec Power Pulley was installed with new belt and remanufactured alternator. The distributor is a Rennwerks Gen II triggering an MSD 6AL CD box. The exhaust is SSI with M&K sport muffler. It sounds great. Rebuilt 3.0 starter Numbers matching 5 speed transmission was completely rebuilt. The rotors are updated to vented and drilled. The calipers were rebuilt and modified to suit the vented rotors. New custom pads were installed. Braided stainless lines. The wheels are Fuchs 16x7 (205 x 55) rear and 15x7 (195x55) front that were blasted and painted then clear powder coat by Al Reed. The wheel bearing and seals were replaced. The shocks both front and rear were replaced with Kyoba (KYB) gas. Custom front strut brace. We replaced the carpets and trunk liner and installed Corbeau Vintage seats. Prototype Hargett pedals. Seat belts are updated to 72-73 Porsche retractable shoulder harnesses. The door panels are Carrera 2 RS without pockets. Head lights are H4, the 4 big Oscars are 100w and 55w. Front and rear turn signal lenses are European amber. New engines mounts Powder coated sheet metal. http://forums.pelicanparts.com/uploa...1744582672.JPG http://forums.pelicanparts.com/uploa...1744582672.JPG |
LP |
I've heard great things about exe tc stage coilovers, definitely not cheap though! I was thoroughly impressed with my Feal 460 coilovers, and I was lucky enough to find a set that had been installed on a failed rally car build, had only been rolled in and out of the garage, and I scored them for about a 1/4 of MSRP at the time. Something like those would definitely be overkill on my build though...the 1000 Lakes valved Bilsteins I'm running should be plenty for spirited gravel road ripping in my longhood. My old Subaru setup... http://forums.pelicanparts.com/uploa...1744669222.jpg http://forums.pelicanparts.com/uploa...1744669222.jpg |
The Feal coilovers are made by a company called HOTBITS in Malaysia. I was the US rebuild facility for a number of years, (03-2012) also helped them with dyno tuning and more. Odi from feal used to get seals from me years ago before feal was selling much. I have those on my g50 Carrera and were on my VR4 rally car too. Lasted a lot of stages miles without failure. They have decent adjustment ranges and are good for the money. Rear of Subie is prone to bending rods because of the length. If you see them weeping, you’ll know why.
If I did exetc again, I’d do singles or just run 1000 lake…maybe reiger. I’m on 19/27 bars with no sways. 300hp 3.0 with SCRS gearing. It’s a beast. Scary in the woods. |
Still some cosmetic work to do but my favorite to drive
http://forums.pelicanparts.com/uploa...1744765364.jpg |
Imho safari builds are already played out, and stupid for most parts of the country.
I'd love some wheel time behind your rally 911, I'm guessing it is nirvana on the stage. I swapped a 3.0 h6 into my Subie that made about 300hp, and I had an 4.44 sti-RA transmission with dccd, so I know first hand the perfection that is 6 cyl torque tied to short gears in a light car on the dirt. And your 911 is a few hundred pounds less than my RS...has to be a rocket ship, scary is probably a big understatement to the uninitiated;) |
In my town, if you're not driving a pickup, you're going to be replacing some plastic quite frequently. For some of us, the Safari builds aren't just an aesthetic choice, but a functional one.
I know I have personally ripped off a 964 bumper on a speed bump in a parking lot (yes, at single-digit speeds) and a 997 bumper on my mother-in-law's driveway. My old Impreza ran over it's front bumper a few weeks into ownership pulling out of my own driveway so I hacked it off halfway down. I've also scraped the heck out of the underside of a Chevy SS, an ND and an NC MX-5, and a WRX's bumpers just driving to work and back. There are some cars I would have loved to have purchased, but decided against strictly due to their terrible approach angles. I will never be able to buy a C8 'vette or a 992. Anything from Lotus or Ferrari will stay on a poster. From this point onwards, if it doesn't have Battlewagon/Safari/Rallycross stylings, I don't think I'll ever purchase another vehicle. |
The vast majority of this country has like zero off road trails; ex: Wisconsin has NO public offroad trails, so unless you own property with private trails, you literally can't use your Safari build properly. Out west, sure, maybe, if you're near appropriate trails, but the vast majority of the country's population is in developed areas without offroad access, so road cars make more sense. |
