Rtrorkt's Avatar
Engine Bay Refresh
This group was helpful in convincing me to keep my 3.2 rather than spend a bunch of money to replace it. Having said that, there is a suggestion to return the heater system to the one that came in my 69 tub. Does anyone have a picture of a 1969 911 engine bay showing the tin and other components? As noted, I have a 3.2 installed. Have attache a picture of the current condition. I am thinking the 3.2 heater, etc is really not being used.
Thank you
'86 944T black/red, chip, fuchs 8's and 9's- Sold
'97 Boxster silver/red, big mistake - Sold
'99 C2, silver/black, RoW M030 - sold
"69 912 white w/ '86 3.2L (like the pic, just not the pic)
Old 04-03-2025, 09:16 AM
Call 911
dkirk's Avatar
I have an SSI exhaust system installed on my '88 with the 3.2L engine. Not wanting to eliminate the engine mounted heater blower, here is what I did:
SSI Exhaust – Heater System Workaround
If you are running this type of exhaust system, you may want to consider this. Heat output is amazing.
Dave Kirk
My Porsche restoreth my soul.
Old 04-03-2025, 11:03 AM
Rtrorkt's Avatar
Thank you for that suggestion, dkirk. Since I live in AZ, heat is really not an issue. My goal is to get rid of the big plastic pipe, etc on the left side and expose the intakes. I think that is why the '69 tin etc was suggested. I have attached a picture of a bay I like. Just not sure how to attain it.
Old 04-03-2025, 12:07 PM
Mr. Merk's Avatar
I deleted the electric blower on my '88 by using a fan duct from an earlier model to get the look you're after and retain the heat function using the engine fan like the '69 did originally.
Like this except I used a black hose:
'87 Carrera Heater blower(s) delete question...
SWB 912 - G50 Carrera - 997.2 911 Turbo - 958.2 Cayenne - 9Y3 Cayenne GTS
SOLD: 958 Cayenne Turbo S - 997 Carrera 4S - 957 Cayenne Turbo
Workshop Coordinator at Ehrlich Motorwerks
instagram.com/patrickossenkop
ehrlichmotorwerks.com
Old 04-03-2025, 01:53 PM
Originally Posted by Mr. Merk View Post
I think that is the way to go. You can replace all the ducting that obscures the intake manifold, but still retain the heater. Search for "heater backdate".
Our host has the key part: https://www.pelicanparts.com/More_Info/93010632101V2PH.htm
Old 04-04-2025, 12:15 PM
Rtrorkt's Avatar
thank you all for your suggestions. I will check tomorrow since there may be a switch under my dash put there by a previous owner that runs fans. Not sure why or what. In the meanwhile th link suggested above does not work.
Old 04-04-2025, 02:06 PM
Still here
pmax's Avatar
The heater fan was added in the later years.
That's why the switch is there in yours. Needs a relay as well if not already there.
Old 04-04-2025, 02:10 PM
Rtrorkt's Avatar
Maybe, but it is clearly an aftermarket tiny toggle.
Old 04-04-2025, 02:36 PM
This guy has a video with all the parts and how to do it:
https://www.youtube.com/watch?v=MXuTpWfD5vQ
Old 04-04-2025, 05:46 PM
Rtrorkt's Avatar
Thank you for that link. Apologies for the tardiness in my thanks, been distracted by recent events
Old 04-07-2025, 06:18 AM
