D@vid's Avatar
Window frame rivet
Hi guys,
At the moment, I'm restoring the window frames of my 1973 911T.
I had to remove all the steel parts prior to anodizing, and now I'm trying to put everything back together again.
The main question I have is: what kind of rivet do I need to use to secure the steel bracket to the frame? Can I use a regular aluminum pop rivet, or is there a special rivet I need?
Kind regards,
D@vid
1973 2.4 MFI
bone-stock 911T
Old 03-31-2025, 02:46 AM
PCA Member since 1988
I don't know for sure what rivets were original, but that looks like steel. I would not use an aluminum pop rivet. I doubt it will be strong enough. How about using a nut and bolt of the correct size?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-31-2025, 11:01 PM
'87 Targa
*Warning:* Ignorant thought from 1987 Targa owner!
Would they use the copper rivets from the Targa wing window cap? PN: 900.056.003.20
Old 04-01-2025, 08:40 AM
D@vid's Avatar
Thanks guys, I will explore both options. However I don't really know what tools I need for the copper rivets. Also copper may not be strong enough.
Kind regards,
1973 2.4 MFI
bone-stock 911T
Old 04-02-2025, 12:01 AM
Mark Salvetti's Avatar
Kind regards,
I was thinking about those copper Targa rivets as well. Here is a great thread that shows how to install them for the Targa window stop.
https://forums.pelicanparts.com/porsche-911-technical-forum/566914-question-asked-but-never-answered-how-do-i-install-new-targa-window-stops.html
Mark
1979 911SC Targa
Old 04-03-2025, 11:28 PM
D@vid's Avatar
Thanks Mark,
That might work. Will look into that.
Again, thanks for your input guys.
Kind regards,
1973 2.4 MFI
bone-stock 911T
Old 04-07-2025, 01:53 AM
