The biggest difference with a cat delete is a stinker exhaust, especially in the garage at startup, a deeper and richer sound from the muffler, and maybe a couple of HP. More if your cat was partially plugged.
Most come with a O2 sensor bung, so the computer is happy. And the bypass is much cheaper than a new cat.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Guess again. It's just the opposite, a little richer!
Dave |
i took off the oxy sensor the 1st week i got my 85 911 back in 1996..Those days i even pass the smog in LA, so it is all about adjustment no oxy needed...
Ivan
1985 911 with original 501 587 miles...807 226 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 06-23-2025 at 02:25 AM.. |
Aaaand we're back.
![]() Quote:
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
Agree 100%, if you setup mixture correctly to spec you don't require running a stock O2 sensor. It won't run lean, it actually will run like the ROW cars that have no cat converter.
The O2 closed loop was simply a way to bring mixture back to a baseline if the base mixture drifted off lean or rich. This can occur if fuel pressure goes off spec, a injector or 2 get bad spray pattern or clogged, ... bottom line the O2 closed loop is NOT required even in a USA car. Furthermore, if you have removed the cat converter you really should not be running the stock O2 sensor.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
That cat sounds like someone tried to gut it out?
Steve 75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts. |
But the best way to check is to install a decent WideBandO2 (WBO2) gauge and confirm AirFuelRatio data as follows, with engine fully warm, O2 disconnected: At idle - 13.8 to 14.5 is a decent idle AFR target 3000RPM in 4th gear on level road, this is steady state part throttle check, you want to be in the 14.4 to 14.8 AFR range Then anytime you are at WOT you MUST be less than 13.0AFR, stock chips tend to run richer in the high 11s to low 12s. The important thing is never run leaner above 13.0AFR
No sir. Actually, the unit appeared normal upon a visual inspection. The honeycomb was intact on both the header and muffler sides. Somewhere in between though, the ceramic matrix had given up the ghost.
Thankfully, my curiosity caused me to shake it, otherwise, I may have reinstalled it, none the wiser..
So you want a little more than anecdotal?
![]() This graph shows the car around 2007 with the WOT switch not adjusted correctly on Run 1 & 2, the switch correctly adjusted Run 3 & 4, and Steve Wong chip Run 5 & 6. Car is stock ROW '84 3.2 ![]() This is the same car in 2019 with the only change being 993 Bischoff HE's & M&K 2 in 1 out muffler fitted. Looks to me like about a 5HP gain from the exhaust change. AFR looks a little better also. Both graphs are same dyno, same car, 12 years apart. Funny how our ROW cars don't make anywhere near the reported HP of the lower compression stock US cars!
cheers, Phil 84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies. |
Should be the other way around in reality, we have access to better fuel, hence can take advantage of the higher compression ratio, so not sure what's going on there
![]() Ant. Quote:
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla |
Looks like the transmission is eating near 30% of power. Something has to be wrong here. Engine, trans, or bench.
Gilles RoW 88 Carrera coupé |
But numbers are just that and only relevant when variables are kept consistent, such as using the same dyno, environment etc... I have tuned many motorcycles on dynos with varying results from different dynos. Comparisons become meaningless. A 15% drivetrain loss on a motorcycle is a widely accepted phenomenon (chain & sprocket drive). It's not hard to imagine that a car has significantly more. In any case, the purpose of my post was not about HP numbers but the delta resulting from small changes. I hope this helps some owners out there with their expectations.
cheers, Phil 84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies. Last edited by sus911; 08-31-2025 at 12:37 PM.. |
My car came with the Ruf 9s and 10's. Way too much tire for the car. 235s and 285s I think. No fun at all around town. When I let other folks drive the car they were not impressed w Porsche or with the steering effort.
Not sure how long you drove the 930, but outside of hwy speeds or the track I passed. Now run turbo look wheels, just like the car. Quote:
![]() Last edited by 87m491; 09-01-2025 at 03:18 AM.. |
Finally got the car on a dyno this past Saturday. 134,000mi, and some pretty bad valve guides so I was really looking at a ‘before’ measurement as the engine is coming out this winter for whatever it needs. Currently running a FS euro pre-muffler, dansk 1:1 sport muffler, cup-style airbox cover (mostly for service access) and a SW chip dialed in for 91 octane and the exhaust mods. With an ambient temp of 70 F, it put down 217 at the wheels and 186 ft/lbs. (249 & 213 resp) which far exceeded my expectations, and explained the ease of throttle steering I have been enjoying.
1988 3.2 Carrera sunroof coupe “Rufus” (as in Parnelli Jones) 1974 Triumph Spitfire “The beast” 1974 VW Super Beetle Convertible “Zippy” 2014 Audi A5 S-line 6-sp “Lyle” Last edited by PopsRacer; 09-01-2025 at 06:37 AM.. |
About to pull the trigger on a '95 Carrera. The seller isn't sure if it has the chip or not. The only way to know for sure is to see it on the DME, correct?
Thanks |
A 95 is a totally different animal. It has a chip, but it is not a G body car.
Thread Tools | |
Rate This Thread | |
