Go Speedracer, go!
SpeedracerIndy's Avatar
Slow Carrera - what's wrong
I have an 81 Euro SC, and my father has an 88 Targa Carrera. I spend quite a bit of time in my SC which has no AC, no Sunroof, aftermarket seats and a few other weight savings. My fathers Carrera has all of the standard US comforts like AC, power seats... While driving his car the other day in 93 degree temps, I noticed that it is VERY sluggish. I know that the Carrera has a higher power band, and is quite a bit heavier, but I didn't think that this should have made it feel as sluggish as it was. My SC snaps your head back from a stoplight, while the carrera feels just SLOW. I think that there is something wrong with it. Where do I start? I did notice that the oil temp gague made it to about 2/3 of the way up the gague which seems pretty hot. On a similar day, my SC gague (Euro brass tube oil cooler) doesn't make it even to 1/3 of the way up. I would think timing was off, but it cannot be adjusted in the Carreras. Both cars are bone stock, and I would expect performance to be about equal with the two. The Carrera has had a valve adjustment w/i the last 6000, oil change, new plug wires ($$$ ouch), plugs, dizzy cap and rotor. What do you think the problem could be?
1981 SC ROW Coupe
Old 07-05-2003, 09:55 AM
Team California
speeder's Avatar
Hang on a minute, your SC oil temp doesn't make it to the first mark, (1/3 of the way up, 90deg.C/194deg.F), on a 93deg. day?? There is something wrong w/ your guage or sending unit. I have the same cooler, it is THE BEST, but still the guage could make it to half way up, (~220F), on a 93deg. day. Before, with trombone cooler, it would have been ~30deg. hotter.
As for the Carrera, you need to diagnose it systematically. On this board, there is a popular game known as, "pin the tail on the Carrera/SC/turbo/etc.", which consists of everyone guessing what might not be right w/ your car. Sometimes this is based on real experience, which may or may not be your answer, sometimes it is just bored people on a Sat. afternoon. I will throw the first dart and guess that you have a bad cylinder head temp sensor(?), a common bugaboo on Carreras that will cause the motor to run rich, (I think), all the time and perform like a pig.
I do not mean to discount the help available here, it is phenomenal, but ALL good mechanics diagnose things systematically, (go down the list, eliminating everything less expensive), even if they "think that they know what's wrong". Unless something is really obvious, like a banana in your tailpipe or wheels missing, it is just a guess. Have it checked out or do it yourself, but go down the whole list under the hood, ie. ignition issues, fuel issues, etc. by the book. You have a book, right?
Denis
Old 07-05-2003, 10:53 AM
Go Speedracer, go!
Thanks for the info, very helpfull. First, I already suspected the head temp senson, and have already purchased one but have not replaced it yet. I suspected it because the car runs very rich at startup but runs ok when warm. I didn't know that could make the car run poorly when warm also though. I am on my way to the garage to replace that immediately and see what happens.
My SC never makes it quite to half way. I was a little optimistic when I said 1/3 of the way up. On a very hot day, it will make it almost half way, but never above that. on a cool day, never above 1/3 of the wya. I really need to backdate that gague and sender to have the real numbers on there. the sc temp gague is just terrible. there are only two marks on it and it is very vague.
As far as books, I have the bentley, and a haynes (worthless). Thanks for the help.
1981 SC ROW Coupe
Old 07-05-2003, 11:02 AM
MAS MAS is offline
My 77 911S (2.7) seems to hover between 80 and 90 (C) under normal driving conditions [ 100C is the halfway mark], and on a really hot day with 2-3 hours of driving, around 100 to a max of about 103-105C [212-220 F].
As for the Carrera... it should be at least as fast, if not faster than your SC.
-MAS
77 911S Targa (current car)
87 924S (my previous car)
Old 07-05-2003, 11:32 AM
Team California
speeder's Avatar
Casey, It sounds like your dad's car is running hot, also, and this of course can be caused by the fuel mixture being off in either direction , I just learned this recently from Tyson S. I always knew that a lean mixture or retarded timing= run hot, but rich on our cars will cause the unburned fuel to combust in the exhaust or cat and make for quite a furnace under the heads. Not good, to say the least.
As for your SC, now it sounds just like mine, temp-wise. That cooler is THE BEST factory cooler ever, particularly in slow traffic, (doesn't rely on air movement as much as radiator style). Not sure that I agree about the guage, though, it is actually very accurate and calibrated, you just can't see the #s. Middle of first slash is exactly 90deg.C,(194F), second slash(white stripe) is exactly 120degC,(250F), and beginning of red is 150C, or 300deg.F. OUCH, OUCH!
9 o'clock on our guage would be 220-225deg.F, which is a perfectly acceptable oil temp on a 911, a little less is great as well, of course. Good luck!
Denis
Old 07-05-2003, 11:36 AM
There may be nothing wrong with the Carrera. If your SC has a 7:31 ring and pinion, it will waaaaay out-torque a later Carrera. The Carrera has taller gearing which, unfortunately makes it feel quite sluggish by comparison, especially pulling away from a light. I believe they went to the taller final ratio to meet EPA requirements. Our tax dollars hard at work!
The good news is that his Carrera should pull like a banchee above 4000 rpm.
Mike
89 Carrera 3.6 V-ram #94
Livin' for Targa time!
Want to make God laugh?
Tell him your plans!
Old 07-05-2003, 12:16 PM
Go Speedracer, go!
Well, I think that is what I am experiencing. I replaced the head temp sensor, and no difference, except for better start up. I think it is just the difference that I am not used to. It is amazing to me how much of a personallity difference there is between two cars. His car does pull like crazy above 4000. It's almost like turning on a switch. On the highway, there is nothing like it.
What about the oil temp. Is it normal for a Carrera to be in the upper 2/3 area of hte gague? I didn't get near the red area, but it was above the upper white line. Could this be a sign that the vavles are out of adjustment? I adjusted the vavles about 500 miles ago, and they had been done about 6000 miles before that at a shop. This was my fist attempt at adjusting valves on a 911 so I will be the first to admit that I could have done it wrong. I do konw the proper feel though having done it on VW engines.
1981 SC ROW Coupe
Old 07-05-2003, 03:26 PM
I'm not so sure anything is wrong with the Carrera. Your SC is lighter and not that much less powerful. The 88 Targa's G0 is also geared lower than your SC. My '88 Targa has lost every stoplight grand prix run against my neighbor's '83 SC, and it's not real close, either. But on the freeway, I can walk away from him.
Old 07-05-2003, 03:36 PM
You may want to feel the front oil lines to make sure that oil is getting to the cooler. If the engine is hot, but the lines are not, you could have a bad thermostat. On hot days at the track my temp will run in the same area. There is an oil cooler fan that should come on around the temp you are describing. Does it ever go higher? Might want to make sure his fan is working.
Mike
Old 07-05-2003, 03:43 PM
Nope, a 3.2 shouldn't run that hot. Mine seems to run between 200 and 225. If you get stuck in traffic and sit and idle for a long time the temp will hit the second mark, but that should be the only time (assuming you aren't on the track)
Old 07-05-2003, 03:56 PM
Sonic dB's Avatar
Speaking from my own experience with oil temps....Even in the most demanding LA stop and go traffic, my 3.2 barely got close to the 3/4 line once on the oil temp guage. Most often its dead in the middle or just a hair above.
Old 07-05-2003, 04:03 PM
Poor low end performance and higher than usual engine temps is what I have experienced with an air flow meter that was adjusted too rich which seems to be a common problem with the 3.2's.
Best to deal with it as soon as possible since rich running Carreras have been implicated to have caused premature valve guide wear according to BA.
Cheers,
Joe Garcia
86 Carrera
Old 07-05-2003, 09:22 PM
Go Speedracer, go!
How do you test the AFM to see if it's bad?
1981 SC ROW Coupe
Old 07-05-2003, 09:44 PM
Have the CO checked before the cat.
Joe
Old 07-05-2003, 10:27 PM
Bad news: Your Carrera definately seems to be running way hot
Good news: Low compression Carrera's are all sluggish. So there is probably nothing wrong with it aside from being too hot.
Audi B7 S4
Old 07-06-2003, 03:26 AM
Langers's Avatar
Slow Carrera? What's wrong? Nothing, that's just the way they are. Muwahahahahahaha
2004 VW R32 - B road bahnstormer
1992 Peugeot 205 - Tarmac rally weapon (well eventually...)
Old 07-06-2003, 05:26 AM
Silveresrty911S's Avatar
Casey,
The 3.2 in my 77 has the numbered gauge and on a 90 degree day on a spirited drive it will see 215-230 max. Also it has no external fender cooler, lines or thermostat so your running hottter than normal. I did the blower motor control fix so I can use that for a little extra engine cooling. Try running and feeling the lines like suggested above and keep us posted.
Rick
'76 Carrera 3.0, track
'77 3.2 targa, back home
'95 993 C4 M030, SOLD
PCA San Diego
Old 07-06-2003, 07:43 AM
Not mine, at least, until I got my air flow meter set right!
I dialed in so much low end torque that taking off in second or even third gear is no problem...and that's without smoking my clutch.
I couldn't do that with my 79 SC.
That explains why some 3.2s are blazing fast while others are just plain slugs off the line.
Cheers,
Joe Garcia
86 Carrera
Redwood PCA since 1976
Old 07-06-2003, 08:13 AM
That Carerra is running hot. Mine will just barely get above the second white line, not even close to half way. Hard to say if that is the reason it is running sluggish, or just another symptom of what is really wrong. Somethings up though, be happy to compare side by side with mine. Available all day today.
John
86 Coupe - Sold
Macan GTS
Ducati Multistrada
Old 07-06-2003, 08:15 AM
Mine was very sluggish until I put a test pipe on( I'm still testing)
and changed the stock chip for an authority model for the 3.2.
Does your dad run premium or regular?
Keith- 87 slant nose cabriolet wide body carrera.
Old 07-06-2003, 12:28 PM
