Backup Switch Wiring
Dropped engine for clutch replacement (upgrade due to slipping clutch at WOT .7 bar boost) and when putting everything back together, discovered one of the push pin connectors for the reverse light switch broke off the wire. Search internet and nobody has any repair kit or listing for wiring harness. Anybody out there ever repaired the push connectors?
Hi
It is a bullet connector. You may be able to repair the wiring harness by salvaging the original "bullet". Drill thru the "Bullet" and then solder the wire in place. Or P/N 999-652-102-10 From Pelican Cheers |
10-4…just ordered.
ROW '78 911 Targa
Newer style is 91161290701
They solder on the end of the wire. Not through as the earlier ones did.
