| Registered |
				Confused About G50 Gearbox Starter Mounting Studs
			I am thinking of buying a different G50 gearbox for my '87 Carrera. I have not removed the gearbox or starter before from my car. I'm confused because I've seen pics of G50 gearboxes that have 2 studs on the gearbox for the starter barrel nuts taken from a thread here on the forum:  But I've also seen other pics of G50 gearboxes where only the lower stud is in the gearbox. The other side is just a hole that is not threaded, like this pic (also from this forum):  What's the deal? I don't know what I have but for the one with only 1 stud how is the other side of the starter held to the gearbox housing? The one I'm looking at buying is a G50/01 and it only has the one stud. In my '87, per the PET, there is only 1 stud:  Can anyone shed some light on this?
				__________________ 1987 911 Carrera coupe - Guards Red 2010 997.2 C4S 6-Speed 2005 Mini Cooper Convertible (R52) - Wife's car 1977 VW Bay Window Camper Bus | ||
|  04-30-2025, 06:15 PM |
| Registered Join Date: Feb 2009
			Isn't the upper stud for mounting the gearbox to the engine. The stud is very long and threaded into the block.
|  04-30-2025, 08:57 PM |
| Registered Join Date: Nov 2008 Location: Toronto
			^ Yes.  When the trans is mated to the engine you will see the stud. When the trans is removed, you will not see the stud.
				__________________ '87 911 GP White "casper" '79 930 Copper Brown Metallic "beast" '93 968 Amazon Green Met "moby" '97 Esprit V8 "flat eric" '97 993 Speed Yellow "tbd" | ||
|  05-01-2025, 02:39 AM |
| Registered |
			OH!!! Of COURSE! Good god, how dumb am I? Thanks guys!
|  05-01-2025, 05:38 AM |
